Wireless Home Internet
PostPosted: Mon Aug 08, 2005 10:58 pm    Post subject: Wireless Home Internet Reply with quote
So in the new places there aren't many cable jacks, no crawl space that I have found... so I need to hook up wireless for two laptops and a desktop.
Anyone have any experiances/preferences with brand and what I need?
I need the wireless router.
Desktop Card (are the USB ones okay?)
And 2 notebook cards.
Mike I know you just did alot with this...
Linksys, Dlink? etc? Or just Frys and what's on sale?
Wolffy
PostPosted: Tue Aug 09, 2005 4:09 am    Post subject: Reply with quote
linksys, dlink are both good
if your going broadband, check with your isp, they may suggest something
i have a linksys wireless router & cable modem
youl want to see what features they have compared to each other too
PostPosted: Tue Aug 09, 2005 4:16 am    Post subject: Reply with quote
Yup, you should be fine with any brand name, I would avoid the super cheap Fry's special if it is a non-name brand. I would also really think about going with the 802.11g stuff now, that it is out, don't bother with the old tech, since you are needing to get everything.
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Tue Aug 09, 2005 5:51 am    Post subject: Reply with quote
I have linksys wireless G router / 4 port switch running 128 bit WEP encryption and I picked up a $12 usb adapter for the wifes' notebook from Frys and it works just fine Razz
The G router is almost 5 times faster than 802.11b, but can also interoperate with any 802.11b device (at 11Mbps)
These are about 60 bucks now
The PCI adapters for desktops are good if range is a problem, they have a good size antennae.
I know Comcast wants to charge you for any and all PCs hooked up by assigning a static IP so perhaps avoid any of these types of discussions if your ISP does the same.
PostPosted: Tue Aug 09, 2005 6:43 am    Post subject: Reply with quote
That is what the router should solve, you still get on DHCP address form them, which the router receives, all the internal PC's get private address', basic NAT'ing at work. Unless you somehow set the router into some sort of bridging mode, there is no way your ISP will know that you have anything other than a single machine (as you are just using 1 IP, and 1 machine connected to it.
FWIW, I had to call Comcast support, and explained my setup to them, they seemed to have no problem with it.
PostPosted: Tue Aug 09, 2005 10:04 am    Post subject: Reply with quote
Had three computers running at the folks house with just a hub. Guess for the extra $5 now you get 5 IP addresses. It used to be that it was $5 per computer. From Comcast, which is what we have here too.
Looks like Linksys is the way to go. Found a router/notebook card kit for $99. And Frys has a PCI card from them for $39.
Thanks guys!
PostPosted: Tue Aug 09, 2005 10:27 am    Post subject: Reply with quote
I'm so going war-driving thru your neighborhood. Very Happy Razz
PostPosted: Tue Aug 09, 2005 11:48 am    Post subject: Reply with quote
Ok first of all, where exactly are you living now Very Happy hehe - surprised no one called you out on that or maybe I am just behind the times.
Like several others that have chimed in I used linksys equip. I also have comcast and have had absolutely zero problems with setup or operation (and no extra charges). Give me a call if you need anything.
Wolffy
PostPosted: Tue Aug 09, 2005 2:37 pm    Post subject: Reply with quote
i too have comcast & no additional charges
if you should ever happen to need to call them for support thou, the first thing they will tell ya is to remove the router & try it, of course
yeah id get the newer G protocol ( I think it is) its the 54 meg speed one) or if there is something faster out now
PostPosted: Wed Aug 10, 2005 10:54 am    Post subject: Reply with quote
War-driving?
PostPosted: Wed Aug 10, 2005 12:28 pm    Post subject: Reply with quote
btw I do have the .11g with speedbooster!
PostPosted: Wed Aug 10, 2005 12:56 pm    Post subject: Reply with quote
War-driving?
Its what they call the guys who drive around with a wireless card, and find out where open wireless networks are.
PostPosted: Wed Aug 10, 2005 1:37 pm    Post subject: Reply with quote
Everytime I drive around datalogging I get that popup box coming up. "New network detected! Hold on while we connect!" Like I care! Geez...
ET phone hoME
PostPosted: Wed Aug 10, 2005 9:15 pm    Post subject: Reply with quote
ok dlink and netgear are the only two you want to pick from. i work in this industry. you need a wireless router preferably b/g (both) compatable. also usb card do work but they generally are b and only 11 mbps so the other types of cards which are g type are best and can get 54 or even 108 mbps
1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops.
85 T/A WS6
PostPosted: Fri Aug 12, 2005 3:00 pm    Post subject: Reply with quote
Smile
