Posted: Mon Jul 18, 2005 3:39 am Post subject: WooooHooooo!!! |
View Tracking Summary
To see a detailed report for each package, please select the View package progress link.
Tracking Number Status Delivery Information
In Transit -
On Time
Sched. Delivery: Jul 22, 2005
Shipped to: GRESHAM, OR, US
Service Type: GROUND
Hehe, now I get to keep you all in suspense as to what is happening to the Camaro next. (yeah, just had to post that, because I'm excited. _________________
Wolffy Member
Posted: Mon Jul 18, 2005 4:21 am Post subject: |
nothing to be excitied about here citizen, keep moving along, once he gets it, itll sit in his garage for 3+ years
not that i used to be able to say much, my stuff sat for 2 years |
Posted: Mon Jul 18, 2005 10:32 am Post subject: |
Finally get the superchargers from leaking in the mailroom? hehe
What ARE you doing??
Adapters! |
| No, Springs! |
Posted: Mon Jul 18, 2005 10:36 am Post subject: |
| Twilightoptics wrote: | | No, Springs! |
Ding, ding, ding.
We have a winner. |
Posted: Fri Jul 22, 2005 5:32 pm Post subject: |
Well, I got everything.
Wolffy Member
Posted: Fri Jul 22, 2005 6:06 pm Post subject: |
ooohh those will look really purty sitting on the shelf with everything else
Posted: Fri Jul 22, 2005 6:29 pm Post subject: |
Oooooooo, weight jacks. I've thought about that setup. What lb are the springs? _________________
Posted: Fri Jul 22, 2005 7:00 pm Post subject: |
| 750/175 |
ET phone hoME Member
Posted: Fri Jul 22, 2005 10:58 pm Post subject: |
what does a set of those cost? i should buy all new springs. and whatever else i need with them _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
Posted: Fri Jul 22, 2005 11:10 pm Post subject: |
Really? Are you planning on swapping with stiffer at any point? What swaybars/shocks are you going to be using with those springs? |
Posted: Fri Jul 22, 2005 11:54 pm Post subject: |
| I have the Tokico Illumina's on the car now, and Spohn sway bars (37/25). I will likely go to stiffer springs at one point. I got the kit used on TGO for $250, so I didn't pick the spring rates. I'll drive it, and see how it feels, then descide if I want to go higher, or what I want to go to. |
Posted: Sun Jul 24, 2005 11:08 pm Post subject: |
Hmm where can I get much stiffer rear springs? You said springs were cheap right?
When is that going on? You need to get those wheels and new rubber dude! |
Posted: Mon Jul 25, 2005 3:31 am Post subject: |
Paul,
You would have to get the proper G-C spacer to use the GC rear springs.
If I were you, I would get these. http://www.pitstopusa.com/detail.aspx?ID=23985
Those will allow you to run a startard 5" race spring in the rear, then you just order 5" springs from anywhere that sells them (summit, coleman, etc.). |
Posted: Mon Jul 25, 2005 10:29 am Post subject: |
Is that 5" width or 5" height? I need stock height, but my springs now have two factory spacers and are cut and they are too soft.
Looks like that is for front? And adjustable? |
Posted: Mon Jul 25, 2005 10:51 am Post subject: |
| no, that will use a 5" diameter spring, you would buy a 9" tall for the rear, and use that adjustable spacer. You can then set your ride height where you want. That adjuster will fit over the stock spring mount, and then the spring will seat on it. |
CheezX Member
Posted: Tue Jul 26, 2005 10:46 am Post subject: |
| Twilightoptics wrote: | | I need stock height |
There's the problem!  |
Posted: Tue Jul 26, 2005 1:02 pm Post subject: |
| CheezX wrote: | | Twilightoptics wrote: | | I need stock height |
I thought only red cars were allowed to "spark"?  |
CheezX Member
Posted: Tue Jul 26, 2005 4:34 pm Post subject: |
| Twilightoptics wrote: | | CheezX wrote: | | Twilightoptics wrote: | | I need stock height |
Mine doesn't really have a problem with that.  |
Posted: Tue Jul 26, 2005 7:48 pm Post subject: |
Yours is that low and doesn't scrape?  |
