scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Wed Oct 04, 2006 7:50 am Post subject: New 3:73 motive Ring and pinion |
This is for the 10 bolt 7.5/7.625 carrier, 3 series.
I bought a spacer to put this on a 2 series, but Iam not happy with the way it slops around until its bolted up tight. You must use a dial indictor to tap it in for a true, zero run out.
So I just ordered thicker gears in this ratio to go onto a 2 series carrier.
These gears have never been run, but they do have some marking compound on then for pattern checking.
So you get the new motive gears and the spacer, if you need it.
Make me an offer, I think I paid around $180 for the gears and 20 for the spacer.
Send me a PM and make me an offer.
I want to get rid of them
Thanks
Scott |
