Is Mangus still around here?
PostPosted: Tue May 17, 2005 8:38 am    Post subject: Is Mangus still around here? Reply with quote
Hey Mangus, you still hanging around here? I had a couple of q's about the ALDL defs in tunerpro.
Mangus
1989 Pontiac Trans Am
PostPosted: Tue May 17, 2005 2:23 pm    Post subject: Reply with quote
word
PostPosted: Tue May 17, 2005 8:10 pm    Post subject: Reply with quote
Hey I wanted to see if you knew of a ALDL def for the 8746? I haven't seen one on your site, but thought you might know of someone who has one.
Mangus
PostPosted: Thu May 26, 2005 2:49 pm    Post subject: Reply with quote
I believe it is almost the same as the 7747 (which is almost the same as the 8747), but with a few bits (flags) changed. In any case, you should be able to use 7747.
You could always create one in about 10 or 15 minutes.
