Posted: Wed May 11, 2005 3:58 am Post subject: 16" Wheels or larger |
Hey,
I'm just looking to see if anything is available.
16" Wheels, pretty much anything execpt for the firebird aero style. something like GTA, IROC, 91-92 Z, etc.
if someone happened to have a set of 17's for a good deal, i might be interested in those also.
(I will add, I am pretty cheap ) _________________
PonchoTA Member
Posted: Wed May 11, 2005 5:13 am Post subject: |
I've got a great set of tires for those too when you get 'em!
 _________________ Paully |
Camaro350Z28 Member
Posted: Thu May 12, 2005 7:51 am Post subject: |
i got 2 rear iroc early style stripped and need to be paint and clearcoated... just find two fronts.. _________________ 1985 Z28. Don't know what im doing stupid 4th gen broke me.
Best 1/4 - 13.8 @ 101.98 60' 2.27 |
Posted: Thu May 12, 2005 7:58 am Post subject: |
| I may take you up on that, if someone has a couple of fronts. Having just 2 doesn't do me a ton of good. |
Posted: Thu May 12, 2005 8:49 am Post subject: |
Get that mullet rake action going on Lama boy
O_o
Posted: Thu May 12, 2005 10:45 am Post subject: |
| I need a pair of fronts too! First Series Iroc. |
ET phone hoME Member
Posted: Thu May 12, 2005 5:03 pm Post subject: |
does it really matter if theyare labeled front or rear? whats the difference? wont any 16" that is 5x4.75 fit on either front or rear? _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
Posted: Thu May 12, 2005 5:23 pm Post subject: |
front and rear have diff offsets.
Posted: Thu May 12, 2005 6:43 pm Post subject: |
If you try to put a rear wheel on the front, you'll find out that the wheels wont roll. Every time I get new tires, I tell the tire store they're different.. Every time they balance them all the same, then put the wrong ones up front.. go to back off and the front tires skid.. Luckily they havent broken anything yet.  |
Posted: Fri May 13, 2005 10:43 am Post subject: |
what exactly is an offset and why does it prevent the wheel from moving? cant you get wheels that are fully interchangable? _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
kurfbird Member
Posted: Fri May 13, 2005 12:33 pm Post subject: Back spacing |
I have the shims for the 16 in rims for sale. Asking 15.00 shipped. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Fri May 13, 2005 3:49 pm Post subject: Re: Back spacing |
| kurfbird wrote: | | I have the shims for the 16 in rims for sale. Asking 15.00 shipped. |
Shims are like 1/8th" and were made, from what I understand, to keep the wheels from sticking to drums or something of that nature.
I have the shims on my off my old car for the back, they don't do anything and with them on the front the wheels still rub. |
kurfbird Member
Posted: Sat May 14, 2005 12:05 am Post subject: Shims |
Shims were designed for the offset on the rear wheels only on iron drum brakes. Aluminum drums did not need them. 16 in rims were made front and rear only. If you had drum brakes on the rear you have the shims. They were also to help keep the rims from sticking to the drums.
Some say you don't need the shims. I figured for the small price for the shims I would rather be safe than sorry.
You don't put the shims on the front. And you can't put rear only rims on the front.
Bruce _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
laegion Member
Posted: Sat May 21, 2005 8:22 pm Post subject: |
you can put the front rims on the rear though, imo it looks better with the offset that the fronts have. if i was going to do stock 16's i'd get two sets of fronts. _________________ 95 vw jetta gl
currently looking for a cheap ninja 250 or 500 or comperable 2cyl sportbike. |
