Cascade Crew Message Forums
Wolffy Member
Posted: Sat May 21, 2005 8:33 pm Post subject: i think I caught whatever Brandon has |
well after 3-4 weeks of working on my iroc trying to get her ready for cows i finally got her back on the ground tonight, i need to have the front end checked out, there's something wrong i can tell, but not sure what yet.
heres my laundry list of things ive been doing
swapped from drum to disc rear end (found out the shop that setup the rear end didnt put any fluid in it tonight, i think i got lucky & didnt burn it)
also installed the LCA's from Mike
swapped in a 145 speedo & the gears in the tranny for it
installed my HSR
installed the NOS system
installed the 58mm TB
installed the B&M megashifter
installed a Lokar shift indicator, cause the B&M indicator is a POS
installed my TGO hood
almost done fabricating a new console plate for the B&M & the shift indicator
fabricated a mouting plate for the NOS activation solenoid (yours is ready unca, bringing it with me)
finally got the right prop valve installed & the brakes bleed
i still need to get the following done
interior installed, almost done painting it all, thanxs Paul for the paint idea
make & get powder coated & install a 4 point roll bar, so i can install the 4 point seat belts
get the front windows tinted
pick up some dual lock (its like velcro) so i can install front & back blackouts (thanxs again Paul for the rear ones)
pickup & install a new steering wheel
try to tune the computer some
sand & primer the hood
install the door pins from andyz28, they are nice, greasable too
fill the NOS bottle
i think thats about it for now
i just ordered some new door panel backs, so i can finish the custom interior thats in progress
Posted: Sat May 21, 2005 9:39 pm Post subject: |
Awesome Wolfy! Sounds like you are making up time quickly. I look forward to seeing you and the Z at Cows.
