305 vs 350 question
miamivice
1982 Pontiac Trans Am
PostPosted: Thu Apr 21, 2005 8:12 pm    Post subject: 305 vs 350 question Reply with quote
hey ya'll,
got a question for you guys about what the exact diffrences are between the 2 engines. now i know that the block size is the same between the two. i also know that you cannot make a 305 into a 350 by boring it out and what not, but why is this so?
thanks
Jess
Administrator
PostPosted: Thu Apr 21, 2005 8:24 pm    Post subject: Reply with quote
350 = 4" x 3.48"
305 = 3.735" x 3.48"
The external dimentions are the same, but internally besides bore size I'm not sure exactly. I bet Brandon can fill in the blanks though. Wink
'88 Formula
'95 Trans Am - Sold
'88 GTA - Sold
'89 Firebird V6 - Sold
PostPosted: Thu Apr 21, 2005 8:41 pm    Post subject: Reply with quote
Same stroke but cranks are weighted different to make up for the different size pistons. Also usually the rods are just slightly lighter in the 305. The reason you cant bore a 305 to a 350 is that the cylinder walls arent thick enough. If you bore the 305 out to 350 size you'll hit water, or the walls will be so thin the combustion will just break them.
miamivice
PostPosted: Sat Apr 23, 2005 10:57 pm    Post subject: Reply with quote
thanks dudes
