aldl & datalogging ?'s
Wolffy
PostPosted: Sun Apr 24, 2005 6:58 am    Post subject: aldl & datalogging ?'s Reply with quote
ok you prom burner guys
yesterday i hooked up a aldl cable & tried datalogging, i tried tunerpro rt & winaldl
i couldnt get tunerpro to work, winaldl i got some info, but the blm chart & others wouldnt populate, mianly just the raw data chart, any ideas??
PostPosted: Sun Apr 24, 2005 8:52 am    Post subject: Reply with quote
the BLM data in winaldl won't populate until you reach closed loop. so unless the car got up to full operating temp, it won't fill anything in, other than raw data, and sensor data.
Wolffy
PostPosted: Sun Apr 24, 2005 9:08 am    Post subject: Reply with quote
ah thats why, it was just running in the garage for a couple of minutes
well as i dont have any brakes currently, that will have to wait for now
thanxs dewey
PostPosted: Sun Apr 24, 2005 11:44 am    Post subject: Reply with quote
I like Craig Moates software. Doesn't Winaldl still update slow in comparison?
PostPosted: Sun Apr 24, 2005 1:40 pm    Post subject: Reply with quote
yes i beleive it only does 160baud. Craigs software is the way to go for TPI setups.
CheezX
PostPosted: Sun Apr 24, 2005 1:55 pm    Post subject: Reply with quote
I used to use craig moates' program on my old 486. Now I use Tunerpro RT, works perfectly. It lets you modify the ALDL data fields for when you change the data stream around. You can do lookup tables too for non-linear data fields like the WB O2 voltage to AFR conversion (if you log it through the stock ECM). Pretty cool stuff.
