1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Mon Aug 22, 2016 10:38 pm Post subject: Tranny fluid |
| Can't seem to get a straight answer on this, but what transmission fluid should I use in my nwc T-5? Gear oil or ATF? |
Posted: Tue Aug 23, 2016 6:17 am Post subject: |
There never seems to be a straight answer on the internets.
Your transmission should have a tag on the side specifying which fluid it takes, that is the way to know for sure.
That said, I am pretty sure they all take ATF. |
Posted: Wed Aug 24, 2016 6:24 pm Post subject: |
They have a small pump made of plastic. Thirdgen T5 uses ATF due to clearances. _________________ A redline a day keeps the carbon away! |
Posted: Sun Aug 28, 2016 1:34 pm Post subject: |
| I've always run parts store ATF without any issues, including running it in old S10 T5's. |
Posted: Mon Aug 29, 2016 9:11 pm Post subject: |
| I had a synthetic ATF in my T5 with a bottle of Lucus Auto trans additive. Stuffs thick like 90wt . Right or wrong it survived many years of abuse |
