83 lsx project thread
91camaro_rs
PostPosted: Sat Aug 16, 2014 7:55 pm    Post subject: 83 lsx project thread Reply with quote
well i think last i posted up here was whether i should buy that 5.3 or not....well i did and got a free shell so here is my progress. ill keep updating this as i go
currently im in the middle of putting on new weatherstripping and door handles and locks. after that i have a 91 dash to swap in, andy rolled my ODO back to all zeros. and within then next two weeks i should be taking in the block to be cleaned up and im ordering some stuff for LS1 brakes. just picked up a 4th gen rear the other day too! yes this is a rattle can paintjob. im trying to see how low cost i can do this car. so far im hardly at 500
PostPosted: Sun Aug 17, 2014 9:15 am    Post subject: Re: 83 lsx project thread Reply with quote
Now that's a low-buck build I can get behind! Thumbs up
PostPosted: Mon Aug 18, 2014 9:31 am    Post subject: Reply with quote
How much did you score that 5.3 for?
PostPosted: Mon Aug 18, 2014 10:17 pm    Post subject: Reply with quote
Cool! This will be fun to watch. Cool
91camaro_rs
PostPosted: Thu Aug 21, 2014 7:45 pm    Post subject: Reply with quote
$150 for EVERYTHING ecm harness intake to oil pan, i sold the accessories and exhaust manifolds for $180 lol
i just ordered LS1 calipers for the LS brake swap and i also ordered a harmonic balancer, PS bracket and a alternator with one bracket, still need the other alt bracket and the water pump and belt tensioner and accessories will be complete, the motor is at the machine shop now!
PostPosted: Sun Aug 24, 2014 2:34 pm    Post subject: Reply with quote
WHOA!! That's not a good deal. that's insanity. Guy must really wanted to get rid of it.
PostPosted: Sun Aug 24, 2014 5:15 pm    Post subject: Reply with quote
That's the going rate for an iron 5.3 core, dude. There's another one on craigslist right now for $125 that needs main bearings, and a 6.0 for $650 that has a bad lifter.
Truck motors are good cheap power now. No more of this two grand for a pullout nonsense. Laughing
It's actually had me thinking that I could pick up a beater Chev pickup for under a grand, throw $2K in parts into it and have a decent street racer. But then I remember I don't have a shop or most of my tools anymore and I say f**k it and just buy more beer.
91camaro_rs
PostPosted: Mon Aug 25, 2014 12:44 pm    Post subject: Reply with quote
How is not a good deal if I basically got paid to take it... lol
Scored some stuff at the junkyard and I seperated the wiring harness. So it's individual wires/sensors right now. Ls1 calipers and custom rocker badges are in the mail
PostPosted: Mon Aug 25, 2014 5:15 pm    Post subject: Reply with quote
Oh you got a deal, don't get me wrong. I was merely pointing out to Chris that it wasn't the jaw-dropping insanity he thought it was. Laughing
What ECM and tuning setup are you going to run?
91camaro_rs
PostPosted: Mon Aug 25, 2014 10:38 pm    Post subject: Reply with quote
for now im going to just send in the truck ecm to be reprogrammed. although when i looked up the numbers on it everything that came up was LS1. then once its running gabe and i are gonna pitch in to buy HPtuners and he said he would help me tune
PostPosted: Mon Aug 25, 2014 11:17 pm    Post subject: Reply with quote
I have hp tuners...
91camaro_rs
PostPosted: Tue Aug 26, 2014 10:36 pm    Post subject: Reply with quote
well then i may be in need of your assistance Cool
91camaro_rs
PostPosted: Wed Aug 27, 2014 3:45 pm    Post subject: Reply with quote
Well the guy didn't hear me when i said the pistons were stuck in place....so I might be needing new ones if they have troubles getting em out. We'll see what happens
91camaro_rs
PostPosted: Mon Sep 08, 2014 5:36 pm    Post subject: Reply with quote
motor is getting picked up tomorrow and LS1 water pump is on the way! im getting super close! just need a cam, oil pump and gaskets and new bolts and motor can go together!
PostPosted: Mon Sep 08, 2014 10:30 pm    Post subject: Reply with quote
You using a Z06 oil pump?
What cam are you using?
91camaro_rs
PostPosted: Tue Sep 16, 2014 7:36 am    Post subject: Reply with quote
im going to be using the LS6 cam, LS6 springs are already installed, and im not sure which pump i want to use yet, either a ported LS6 pump or a melling high pressure
i also have been junkyarding every week, been finding all the black interior stuff i need for really cheap, also found an AUJP prom in a 91 firebird sold it on ebay for 135$
im in need of some wiring tech/help im putting in a 90-92 dash into the 83 that has no vats, do i need to modify the wiring to bypass anything or can i just cut out all the vats and airbag stuff?
91camaro_rs
PostPosted: Sun Oct 26, 2014 4:13 pm    Post subject: Reply with quote
well turned out the cam from the 5.3 was shot, and the dude at the shop (bowtie performance) didnt line up my cam bearing right, that was a few weeks ago i took it back to him with a vette ls1 cam i got, so he can re do bearings, also i have been junkyarding like crazy and i have a full black interior minus the door panels, i deleted all the factory seatbelt holes too! ill be getting the motor back first week of november, i only have sundays off and they arent open to pick it up Sad i also scored some ls1 brake rotors for $50 for all 4, took em to work and turned em. so i just need the caliper adapter plates, then ill cut up my hubs and spindle for the brake swap. and i started the wiring sorta, unpinned all the wires from pcm plugs deleted everything i didnt need. gonna run one wire at a time and put the pcm in factory ecm location. slowly making progress!
91camaro_rs
PostPosted: Sun Oct 26, 2014 4:51 pm    Post subject: Reply with quote
this photo sums up my entire project, im going for a factory LS based Z28 look. so i had badges made to fit the look
intake, oil pan and water pump
rare piece i found, a factory berlinetta console mounted fog light switch
dash swap progress
Iroc fog lights i got for $10
the block, went with a cast iron color
4th gen dash emblem
anddddd some rotor turning action
91camaro_rs
PostPosted: Tue Nov 11, 2014 7:47 pm    Post subject: Reply with quote
just ordered:
BTR Head Bolts
Melling 10295 Oil Pump
LS7 Lifters
BTR pushrods
last up is timing chain, then i can assembly the long block, including front and rear covers and oil pan, then once i get my knock sensors i can throw the intake on
91camaro_rs
PostPosted: Sun Feb 15, 2015 4:17 pm    Post subject: Reply with quote
okay been a while since an update...
Motor is totally built and ready to drop in, but i have some things i gotta do first. i just ordered UMI subframe connectors, 8pt roll bar from Art Morrison. Founders LCA's and panhard w/relocation brackets.
I did finally acquire a T56!! just need a new clutch for it
Dash is in, new steering column from a 92 installed because i didnt want to convert all the wiring, i rewired all the tail lights and most of body harness. steering wheel is installed, brake proportion valve installed. hood is on with new hood struts
i also have an entire black interior for it minus the door panels. and i also installed the the quick ratio steering box. i have been finding lots of little things i need at the junkyard too
