2011 Dyno Results
Goto page Previous  1, 2, 3, 4, 5, 6  Next
91camaro_rs
PostPosted: Tue Mar 22, 2011 3:30 pm    Post subject: Reply with quote
ok im super confused now. i dont know which graphs under tunder pro to make adjustments too
MrMike98
PostPosted: Tue Mar 22, 2011 4:00 pm    Post subject: Reply with quote
welcome to the wounderfull world of ECM tuning............
the best way to BEGIN is to read the howto tune ecm articules in DIY PROM board on 3rd gen dot org. they are pretty much step by step .. AND its exactly the information your are looking for..
WBO2 is a must after basic tuning.....dyno would help, but we have some long steep hills that work almost as good..
good luck
Mike
PostPosted: Tue Mar 22, 2011 4:35 pm    Post subject: Reply with quote
What ECM and setup are you running again?
91camaro_rs
PostPosted: Wed Mar 23, 2011 10:42 am    Post subject: Reply with quote
730 Speed Density, 5.7 350 (bored 30 over) TPI
PostPosted: Wed Mar 23, 2011 12:49 pm    Post subject: Reply with quote
MAP vs RPM table. That's your "BASE" map. All acceleration enrichment, power enrichment, etc run off that table.
91camaro_rs
PostPosted: Wed Mar 23, 2011 7:53 pm    Post subject: Reply with quote
so thats the one i adjust and doing that will result in a change in AFR eventually
PostPosted: Wed Mar 23, 2011 7:54 pm    Post subject: Reply with quote
Yes. For that give RPM and Load/Map/kpa
91camaro_rs
PostPosted: Wed Mar 23, 2011 8:03 pm    Post subject: Reply with quote
i looked on tuner pro and i dont see the Map vs RPm graph anywhere, im using the 8D.xdf
PostPosted: Wed Mar 23, 2011 9:11 pm    Post subject: Reply with quote
In is probably listed as VE 1 table, or main VE table.
91camaro_rs
PostPosted: Thu Mar 24, 2011 8:55 am    Post subject: Reply with quote
If VE stands for Volumeric effeciency then i have 3 tables for it, one for up 1600rpm and one up to 5600 and one up to 6400rpm.
PostPosted: Thu Mar 24, 2011 9:00 am    Post subject: Reply with quote
Those would be the ones.
Do they have a lot of overlap? usually you have one large table, that covers 0-100kpa and the rest of the tables are adder tables, that will cover RPM changes, and that are based on percentage changes to the main table.
Maybe I should just look at the 8d table setup, and let you know, lol.
PostPosted: Thu Mar 24, 2011 10:15 am    Post subject: Reply with quote
How would I do the same thing Luke is trying to do with my MAF '165 in $6E?
PostPosted: Thu Mar 24, 2011 11:24 am    Post subject: Reply with quote
You've got the modded file with the extended VE tables. Wow. I can't believe I remember that. Laughing
PostPosted: Thu Mar 24, 2011 12:20 pm    Post subject: Reply with quote
RS- You get the lovely joy of editing your MAF Tables.
Basically lying to the ECM about the incoming air.
Power Enrichment is a calculated Load vs RPM.
PostPosted: Thu Mar 24, 2011 4:27 pm    Post subject: Reply with quote
Some guys on TGO were saying to mod the MAF Scaler tables and others said no, just the MAF tables. Which is correct? Confused
PostPosted: Thu Mar 24, 2011 5:24 pm    Post subject: Reply with quote
I forget the different between the two.
IMHO MAF is pretty close everywhere but idle.
PostPosted: Thu Mar 24, 2011 6:06 pm    Post subject: Reply with quote
John, why are you trying to break things? Your car had near-perfect A/F on the dyno. Rolling Eyes
PostPosted: Thu Mar 24, 2011 9:22 pm    Post subject: Reply with quote
I still have the previous BIN. I'm just seeing what effect certain changes have on performance. Cool
91camaro_rs
PostPosted: Thu Mar 24, 2011 10:09 pm    Post subject: Reply with quote
ok cool, so on the VE tables how do i know what to change and how much do i change it?
PostPosted: Thu Mar 24, 2011 10:15 pm    Post subject: Reply with quote
That is where the math comes in. But, since your at 160 BLM, you are WAY off, so you can do pretty good sized changes, 10-25% type changes.
If the BLM's get to 128, you got it right.
If they BLM's go under 128, you added too much
If they are still higher than 128, you didn't add enough.
Page 5 of 6
