Posted: Sun Sep 30, 2012 8:04 am Post subject: |
I can make a longer list of common issues with Duramax.
Just because I make a list doesn't mean it happened to me. My 7.3L Superduty had no issues for 6 years. My Chevy Duramax nickel and dimed me to death with something needing fixing every month. Glad to see it go after 6 months. The engine was fine but the truck was falling apart around it. |
Posted: Sun Sep 30, 2012 8:26 am Post subject: |
Somehow I feel we've had this debate on here before.
| IROCDave wrote: | | Superduty has been living on reputation since the late 90's |
The truck in question is a '99. Last really good year for the SD.
In my experience the new Duty's break and break expensively. All Duras break, usually in the front end or fuel system as was already mentioned. Also they get worse economy than any other diesel made over the past three decades.
The biggest problem I have with the Duramax is the stigma that goes along with it. Every time you see one it's some halfway retired old dude towing his boat, or an engineer who wants to look cool in front of the crew, or some foreman. Truthfully I can only recall one guy I have ever seen who actually put his Dura to work. |
Posted: Sun Sep 30, 2012 10:12 am Post subject: |
| Ya. 1999. I love this truck, and while it is a short bed, it will get a lot of use. And from what I read, I should be able to get another 200k out of it at least. I bougjt a Chilton book for it, so I will start to get to know it. Got the wicked wheel coming for Christmas. |
Posted: Sun Sep 30, 2012 1:02 pm Post subject: |
| So earlier it would not start. Would crank and crank, but not fire. Exhaust though would fill up with white smoke. Thick. Never done this since I have had it. Then it just started. Any ideas of where to start with what could be going on? |
Posted: Sun Sep 30, 2012 1:32 pm Post subject: |
| Check the glow plugs and controller. |
Posted: Sun Sep 30, 2012 1:40 pm Post subject: |
Lift pump?
Did you eventually get it started? Did it run fine after that? _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Sep 30, 2012 1:48 pm Post subject: |
| Yes eventially started and drove fine to store and back. Started fine after. Bit you do got to give it a bit o gas to start it sometimes. |
Posted: Sun Sep 30, 2012 1:50 pm Post subject: |
| The white smoke is unburnt fuel. Good sign fuel was getting there but motor wasnt warm enough for ignition. |
Posted: Sun Sep 30, 2012 1:53 pm Post subject: |
| So with me knowing nothing of diesel, is that a sign of glow plugs going bad. I assume if it does this know , then it wi be worse in winter |
Posted: Sun Sep 30, 2012 2:14 pm Post subject: |
Glow plugs or retarded timing.
As B said the thick white smoke is the fuel, so the pump and injectors are functioning.
Ohm the plugs (can be done without uninstalling them). |
Posted: Sun Sep 30, 2012 2:15 pm Post subject: |
Only sign is its hard to start. Did it seem like they cycled on/off too quickly?
I think your engine has the glowplugs under the valve covers. Makes them a bit harder to check. You'll need to figure out which wires are the glow plugs at the valve cover gasket connector. Search your powerstroke forum.. i'm sure this is one of the most popular topics. |
Posted: Sun Sep 30, 2012 2:18 pm Post subject: |
When the lift pump died on my friend's 01 Cummins it ran like crap and spewed thick white smoke. New lift pump and it was all good. Is that not expected? _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Sep 30, 2012 2:22 pm Post subject: |
Dead lift pump = low pressure at the injection pump = retarded injection timing = late burn and white smoke.
Jeremiah's problem is only on cranking when cold, thus an engine heat issue. |
Posted: Sun Sep 30, 2012 2:33 pm Post subject: |
| aaron_sK wrote: | Dead lift pump = low pressure at the injection pump = retarded injection timing = late burn and white smoke.
Thanks. That is what I figured. Maybe I should just be quiet in diesel threads.  _________________ 84 Camaro Z28 - LS1/T56
| They are,under valve covers. They say not to pierce them cause a lot of volts run through them. So I will prob just pull covers and check. For safety reasons |
Posted: Sun Sep 30, 2012 2:39 pm Post subject: |
| jchaussee wrote: | | They are,under valve covers. They say not to pierce them cause a lot of volts run through them. So I will prob just pull covers and check. For safety reasons |
They will be six volt or twelve volt. You should not need to pierce anything, just test at the connector or remove the valve covers and test at the plugs themselves.
| Alphius wrote: | Maybe I should just be quiet in diesel threads.  |
Gotta learn somehow. Eventually we all have to work on a real truck engine.  |
Posted: Sun Sep 30, 2012 3:18 pm Post subject: |
| Alphius wrote: | | When the lift pump died on my friend's 01 Cummins it ran like crap and spewed thick white smoke. New lift pump and it was all good. Is that not expected? |
That's because the redesigned the pump assembly in those.
A good cummins will suck through the lift pump. That specific design, the engine had trouble sucking through a dead lift pump. Lift pumps will die and the customer will never know until the fuel filter is replaced without being filled, and the engine WILL NOT start. _________________ A redline a day keeps the carbon away! |
Posted: Sun Sep 30, 2012 3:21 pm Post subject: |
Is this a high pressure oil setup? If so The lift pump isn't even really a lift pump, it's just like a car, supplies fuel pressure to inject from. No "injection" pump. _________________ A redline a day keeps the carbon away! |
Posted: Sun Sep 30, 2012 4:08 pm Post subject: |
| Twilightoptics wrote: | | Is this a high pressure oil setup? If so The lift pump isn't even really a lift pump, it's just like a car, supplies fuel pressure to inject from. No "injection" pump. |
Yes, Jeremiah's truck is high-pressure oil. I was referring to the Cummins that Gabe mentioned.  |
Posted: Sun Sep 30, 2012 4:11 pm Post subject: |
Ahh.
Go crew and staying on topic! LOL _________________ A redline a day keeps the carbon away! |
