Mmm.... greeeeen...
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Jan 23, 2012 6:19 pm    Post subject: Reply with quote
From the pic, it looks like the driver side header is quite close to the power steering return line. Maybe just camera angle
PostPosted: Mon Jan 23, 2012 6:22 pm    Post subject: Reply with quote
It is not a tuuumaaah!
Is that a fixed reservoir or is that just where the divorced unit is mounted?
Either way maybe a PS cooler in your future. Laughing
It's a type2 pump so the divorced unit is mount directly to the pump. I'm going to look into remote reservoirs. Laughing
PostPosted: Mon Jan 23, 2012 6:28 pm    Post subject: Reply with quote
Was it only the veesix fourthgens that had the reservoir way over on the fender then?
PostPosted: Mon Jan 23, 2012 6:31 pm    Post subject: Reply with quote
No idea! But that gives me one to look at! Very Happy
PostPosted: Mon Jan 23, 2012 6:55 pm    Post subject: Reply with quote
Yep, the 3800 at least has it divorced and mounted to the framerail.
No idea on an LS1 car, I haven't paid that much attention.
PostPosted: Mon Jan 23, 2012 7:04 pm    Post subject: Reply with quote
LS1s are mounted where I have it, it's a factory fbody bracket.
PostPosted: Mon Jan 23, 2012 7:07 pm    Post subject: Reply with quote
Just went out to the shop to grab a pic of mine. This is the factory fourthgen pump, reservoir and lines running into the thirdgen box. The reservoir is just hanging in this picture. There is enough slop in the lines to get it farther out of the way.
PostPosted: Mon Jan 23, 2012 7:36 pm    Post subject: Reply with quote
Do you know offhand if the diameter of the shaft is the same between your 4thgenv6 pump and a thirdgen one?
PostPosted: Mon Jan 23, 2012 7:39 pm    Post subject: Reply with quote
F**k no, not a clue. Laughing
How would the old thirdgen pump help anyway?
PostPosted: Mon Jan 23, 2012 7:45 pm    Post subject: Reply with quote
Laughing As far as I know, shaft diameter is the same between 3rdgen and fourthgen v8 pumps. If I can just pick up a new pump from my work and swap over the pulley that'd be easiest. Smile
PostPosted: Mon Jan 23, 2012 8:04 pm    Post subject: Reply with quote
Just a thought, for my LT1 swap I used the resevoir over on the driver side but I got some stock high pressure lines to actually work. All I needed to do was bend one of the hard parts a little. Not sure if it will work with what your doing but thats how the LT1 ended up.
PostPosted: Mon Jan 23, 2012 8:11 pm    Post subject: Reply with quote
Why change the pump at all? Does the draw side of the reservoir have a rubber line or is it like some press-fit BS? Seems to me like you could mount and sort of reservoir anywhere you wanted and just run the line into the low side of the pump. Shrug
PostPosted: Mon Jan 23, 2012 8:22 pm    Post subject: Reply with quote
As far as I can remember, the res just has an oring fitting to the pump and it's just held on by some clips to keep the seal. I don't remember there being a fitting or tube coming off...
That's exactly what I did for the ls swap. 4thgenv8 hoses fit with just a slight bend to them.
PostPosted: Mon Jan 23, 2012 8:38 pm    Post subject: Reply with quote
If they're just using the normal type-2 pump shouldn't the inside of the inlet be tapped for threads? If not maybe it could be tapped.
If not then you are right about needing to find out which shaft diameter you need. Summit sells a universal unit with a 5/8" shaft like so:
http://www.summitracing.com/parts/SUM-340106P/Application/?prefilter=1
PostPosted: Mon Jan 23, 2012 8:46 pm    Post subject: Reply with quote
Type-2, hose barb on the low pressure line... doesn't list shaft sizes.
http://www.oreillyauto.com/site/c/detail/A1C0/20874.oap
PostPosted: Mon Jan 23, 2012 10:46 pm    Post subject: Reply with quote
Now that looks promising. I hope the orientation is the same as mine, I'll check it out tomorrow. Thanks buddy!
Incidentally, while digging around in the garage tonight "cleaning up" I found all the v-band flanges/clamps and turbo flanges I had ordered years ago. Laughing It's like free parts!
PostPosted: Fri Feb 17, 2012 3:39 pm    Post subject: Reply with quote
So that pump was quite a bit off. Laughing the shaft diameter was much smaller and the bolt holes were smaller and threaded. Oh well.
But I did get my weight jacks in!
PostPosted: Fri Feb 17, 2012 3:43 pm    Post subject: Reply with quote
And it only took three weeks! Laughing
PostPosted: Fri Feb 17, 2012 4:09 pm    Post subject: Reply with quote
The PS pump I knew about the next day, just put it on the back burner while I tacked together the hotside.
Now I need some red spray paint for those springs!
Edit; Laughing Sorry guys I forgot I can't shrink photobucket pictures from my phone! I'll edit when I get home from work.
PostPosted: Fri Feb 17, 2012 9:41 pm    Post subject: Reply with quote
I think GC supports drinking while working on my car. This spanner wrench looks an awful lot like a bottle opener...
Page 4 of 6
