83Z28BlackBetty Bam-Ba-Lam
Posted: Sat Aug 13, 2011 10:32 pm Post subject: |
Found an awesome place called Hydraulic House that was able to make me a totally custom clutch hose in about 5 min. And cost me only $40! Less than half of the dorman piece.
I've started to plan out the engine wiring today. I want the install to be tidy, look factory, and be easy to trouble shoot later down the road.
Buried in my box of wiring fun that came with the swap is the factory fuse/relay box. I started tonight by cutting all the leads and labeling the entire fuse box. I figure this way I can keep all engine related fuses and relays in one place. I'm also thinking about relocating the fuel pump relay and the fan relay to this box.
Maybe I'll have made enough progress tomorrow to warrant a few pics. Now it just looks like a mess of wires on the floor.
-jake |
Posted: Sun Aug 14, 2011 5:17 pm Post subject: |
| 83Z28BlackBetty wrote: | | Found an awesome place called Hydraulic House that was able to make me a totally custom clutch hose in about 5 min. And cost me only $40! Less than half of the dorman piece. |
Sounds a lot like the place I had make my braided brake lines. Small place, but just enough business to keep two guys busy for eight hours a day. I walked in and had 3 brake lines in about 30 minutes for about $60 apiece.
| 83Z28BlackBetty wrote: | I've started to plan out the engine wiring today. I want the install to be tidy, look factory, and be easy to trouble shoot later down the road.
Maybe I'll have made enough progress tomorrow to warrant a few pics. Now it just looks like a mess of wires on the floor. |
Sounds like a fun project you have underway. Electronics can be really fun, or a nightmare, but it looks a if you've got the beginning of it under control. |
Posted: Tue Aug 16, 2011 9:38 pm Post subject: |
Got the fuse and relay box finished tonight. I de-pinned the entire thing and have it now totally rewired. I also drew up an accurate color diagram for future reference if necessary.
Its a pretty simple concept. I have a main relay that receives its signal from keyed power and main power from the battery that powers the line of fuses. Power then goes through Each fuse and provides power to a separate corrosponding relay. Aka fan 1, fan 2, fuel pump, ac compressor clutch. Other fuses will power engine based wiring. Aka injector bank 1, bank 2, O2 heaters, sensor power. This way each relay is easily tested and replaced if necessary, as well as I'm not messing with the under dash fuse all engine based relays and fuses are all centrally located.
Does anyone know if the lt1 maf has a burn off function? Also are there any other engine functions that should be relay driven and other circuits I'm forgetting that need to be fused?
-jake _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Sun Aug 21, 2011 9:40 pm Post subject: |
Started the arduous task of engine wiring today. Remember the post about how i pulled the old harness out of the loom and de-pinned the pcm connectors? This was the next phase of the project. I took each connector bundle and plugged it in to its corresponding sensor and then routed the wires around the back of the engine bay the way i wanted.
I plan on mounting the PCM where the coolant bottle used to go. the problem is the wires aren't long enough to reach there, so the next few days will be spent lengthening wires to reach. here are a few pics of my progress so far.
Posted: Mon Aug 22, 2011 8:42 am Post subject: |
Looking good Jake!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Aug 22, 2011 12:22 pm Post subject: |
Spaghetti mess!!  |
Posted: Mon Aug 22, 2011 1:56 pm Post subject: |
One of my favorite things is seeing that pile of chaos turn into a seamless loom of perfection. _________________ A redline a day keeps the carbon away! |
Posted: Mon Aug 22, 2011 4:58 pm Post subject: |
| Spaghetti anyone? |
Posted: Mon Aug 22, 2011 5:42 pm Post subject: |
Posted: Mon Aug 22, 2011 7:10 pm Post subject: |
[img]http://t1.gstatic.com/images?q=tbn:ANd9GcRpeDge2ViLdjLbY4oO_qKJpYSijTUQ-dguJO9dQcbktL942rc-BA[/img]
Something like that. _________________ A redline a day keeps the carbon away! |
Posted: Mon Aug 22, 2011 8:53 pm Post subject: |
What's stopping you from hiding the ecm where the factory mounts the thirdgen one up under the dash? _________________
Posted: Mon Aug 22, 2011 9:48 pm Post subject: |
| Lmao.. is that supposed to be an attempt at an equal length header? Wow |
Posted: Mon Aug 22, 2011 9:54 pm Post subject: |
Funny you mention that ian, I was thinking the same thing earlier today while looking at pictures of my engine bay.
So I actually measured it out and it looks like my lengthening the wires gave me enough to tuck the loom through the bulk head connector on the passenger side so i can hide it completely.
Now off to get more heat shrink, to think that 8 feet wasn't enough...
-jake |
Posted: Mon Aug 22, 2011 9:57 pm Post subject: |
| chevymad wrote: | | Lmao.. is that supposed to be an attempt at an equal length header? Wow |
Yeah, it looks like somebody wanted to do an equal length header on an inline six.  |
Richster Magic Fingers
Posted: Mon Aug 22, 2011 10:09 pm Post subject: |
Holy Christmas lights!
You got it dialed, well done!  _________________
Posted: Tue Aug 23, 2011 8:54 am Post subject: |
| aaron_sK wrote: | | chevymad wrote: | | Lmao.. is that supposed to be an attempt at an equal length header? Wow |
hehe..or on an inline 5....
Posted: Tue Aug 23, 2011 9:25 am Post subject: |
That wire mess looks like my car about 3?? years ago when I went OBD2.
I extended the wires to go thru the bulkhead and into stock position. IMO it looks much cleaner. I never did like the pcm in the engine bay idea. |
Posted: Tue Aug 23, 2011 12:31 pm Post subject: |
| Dewey316 wrote: | | or on an inline 5.... |
Weirdos.  |
Posted: Thu Aug 25, 2011 10:15 am Post subject: |
Enough of this crazy talk of 5 cylinder headers and italian pasta...
I've just about finished the sensor wiring harness. All that's left is to set up the external connections, fuel pump relay, fan relays, 12v ign, and grounds.
A few questions,
Does a t56 use a park neutral switch? Or can I just use the clutch switch?
I'm Using the pcm to control the ac clutch relay, if I ignore the evap temp sensor, and the refridgerant pressure sensor will I run into problems? Or should i leave the pcm out of the ac loop, except for the ac clutch status wire?
There is a brake switch signal wire on my diagrams that I think is related to tcc, I shouldn't need it for a t56 right?
-jake
Ps, just scored a trick flow intake elbow off craig's list to replace the old ripped rubber boot. Score! |
Posted: Thu Aug 25, 2011 10:25 am Post subject: |
| 83Z28BlackBetty wrote: | A few questions,
Clutch switch yes, park switch no. You have the reverse lockout wired, right?
| 83Z28BlackBetty wrote: | | I'm Using the pcm to control the ac clutch relay, if I ignore the evap temp sensor, and the refridgerant pressure sensor will I run into problems? Or should i leave the pcm out of the ac loop, except for the ac clutch status wire? |
I don't know much about A/C systems but if there are provision for a pressure shutoff switch I would keep it!
| 83Z28BlackBetty wrote: | | There is a brake switch signal wire on my diagrams that I think is related to tcc, I shouldn't need it for a t56 right? |
Does the LT pcm use the brake signal switch to deactivate the reverse lockout or is it only under speeds of 5mph?
Good find on the elbow, that's the metal one, right? |
