Posted: Sun May 19, 2013 8:03 pm Post subject: |
| aaron_sK wrote: | Any displacement can make power. Bear in mind that Al's 383 and Derrick's 305 are within five horses of each other.
Far be it from me to say this, but this build is going too slowly.  |
And my 346 made even more. Displacement isn't everything. It's all about the combo and the tune.
Too slowly indeed. This is a six-pack build. By the time you finish the six-pack it should be done.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun May 19, 2013 11:29 pm Post subject: |
| aaron_sK wrote: | | Bear in mind that Al's 383 and Derrick's 305 are within five horses of each other. |
Bet there is a bigger gap in torque.  |
Posted: Sun May 19, 2013 11:53 pm Post subject: |
| ya. lack of expierience and money are slowing it down. i jist want to finish before dec when 4th child bon or i will never finish |
Posted: Mon May 20, 2013 9:18 am Post subject: |
| RSFreak wrote: | | aaron_sK wrote: | | Bear in mind that Al's 383 and Derrick's 305 are within five horses of each other. |
Only about 100lb/ft. lol _________________
'88 FORMULA |
Posted: Mon May 20, 2013 2:41 pm Post subject: |
| fiveoformula wrote: | | RSFreak wrote: | | aaron_sK wrote: | | Bear in mind that Al's 383 and Derrick's 305 are within five horses of each other. |
Only about 100lb/ft. lol |
And I'm a little conservative on the fuel pressure for now - only 18psi. If I read the calculations right, I might get 300 hp if I bumped it to 22-24 psi, saving that for a different tranny, though... _________________ 92 Camaro
Posted: Mon May 20, 2013 6:52 pm Post subject: |
| So I took my cam in to have it checked. Machine shop said way to much for the street. Whih sucks cause its like a 400 dollar cam. And its a solid roller and the ship says to go witg a flat tappet so I can save a bunch of money. . |
Posted: Mon May 20, 2013 7:00 pm Post subject: |
Not a matter of saving money. You don't have a roller block.
Sell it and buy something that matches your heads and intake better. |
Posted: Mon May 20, 2013 7:31 pm Post subject: |
Why would increasing fuel pressure give you more power, unless you're running incredibly lean now? _________________ A redline a day keeps the carbon away! |
Posted: Thu May 23, 2013 4:41 pm Post subject: |
| So heads are in machine shop geting cleaned and surfaced. my cylinder walls are extremely smooth so a biddy of mine suggested I go all in. so thats what I may do. |
Posted: Thu May 23, 2013 7:10 pm Post subject: |
They should be smooth.... _________________ A redline a day keeps the carbon away! |
Posted: Fri May 24, 2013 5:56 pm Post subject: |
What good is torque if you can't turn it into horsepower??? |
Posted: Fri May 24, 2013 7:03 pm Post subject: |
| I think Al has much more conservative cam in his 383, probably takes alot less RPM to get moving too. |
Posted: Fri May 24, 2013 8:36 pm Post subject: |
| A buddy of mine said was to smooth indicating it has alot kf miles |
Posted: Fri May 24, 2013 8:39 pm Post subject: |
| fiveoformula wrote: | | I think Al has much more conservative cam in his 383, probably takes alot less RPM to get moving too. |
I couldn't get any replies to e-mails or phone calls from the builder as to what the internals are. As far as I know, it's all stock Vortec 350 except for the crank, rods and pistons (which he did tell me were Scat and Speed Pro). _________________ 92 Camaro
Posted: Wed Jun 26, 2013 5:04 pm Post subject: |
So I got my cam.all I got for specs for it were written on a piece of paoer. .236 .520 int
.244 .535 ex
Duration @ .050
On box it says 274r 236-244
So can someone givr me an idea of how thia cam will be |
Posted: Wed Jun 26, 2013 5:24 pm Post subject: |
What's the lobe separation angle?
It could be relatively mild, or it could be incredibly lopey. Depends on your LSA and Compression Ratio/Heads/Intake _________________ A redline a day keeps the carbon away! |
Posted: Wed Jun 26, 2013 5:31 pm Post subject: |
| I dont know the lsa. The guy at delta just wrote those numbers down. I will have to call them the heads are the pri topline srt. 1.94/1.50 with 167 cc intake runner and 67 cc combustion chambers. I was gonna use a performer rpm intake. I had a guy rebuild me a qjet that he set up like the old school ones edlebrock used to make that he said shoukd work well |
Posted: Wed Jun 26, 2013 6:01 pm Post subject: |
| jchaussee wrote: | | can someone givr me an idea of how thia cam will be |
Call Delta or just go down there. They should be able to give you the cam card with the info off your receipt. Hell, they had a card for mine and the only info I had was the shop who built the motor and the approximate date.
| jchaussee wrote: | | a qjet set up like an old edlebrock |
Your carb guy did what now?  |
Posted: Wed Jun 26, 2013 8:47 pm Post subject: |
| Ya. Ill call tommorow. They were closed when I picked it up tonigt. One giy was waiting for me to get there. Computers were down. So was cash. 70 bucks. and carb guy was tellinh me that eldlebrock did some qjt carbs back in tje day? Maybe? and said is is a pretty good setup? Idk. He has like 300 carbs in his shop. Looked like he knew his stuff |
Posted: Wed Jun 26, 2013 11:25 pm Post subject: |
| I guess from what I have been reading he is setting it up lije the qjets thay edlebrock did. From what I have read they were supposed to be decent performance carns. So hopefully it will be. It will be less then 100 bucks whixh inclufes the carb so it is still a decent deal. |
