RK82 Member
Joined: 27 Jul 2008 Posts: 168 Location: vancouver B.C
1982 Pontiac Trans Am
Posted: Tue Nov 20, 2012 1:40 pm Post subject: |
I haven't updated this in while..not much changed, I drove it all summer made it to 5 street legal nights best time was a 15.33 at 88mph.
I added a H-pipe to the exhaust
after the exhaust the car was running alittle lean, when I went to change the jets my elcheapo chrome fuel line twisted off
I may have got carried away with AN fittings and braided line again but I like this setup alot better, I don't even have to take the fuel lines off to change jets. I didn't have a 90* degree fitting so the line for the rear bowl is alittle long.
RK82 Member
Posted: Tue Nov 20, 2012 2:05 pm Post subject: |
Middle of july I took the car on a 1200KM roadtrip to see my parents, I took few pictures along the way.
overheated on the side of the road, really need an airdam
RK82 Member
Posted: Tue Nov 20, 2012 2:59 pm Post subject: |
In front my girlfriends parents house
this seemed like good spot for some pictures, the gravel pit in the back ground of the first picture is where we used to party back in highschool.
RK82 Member
Posted: Tue Nov 20, 2012 4:50 pm Post subject: |
a few pictures of the car going away for the winter
since its that time of year again I've been collecting parts,
black door panels, almost done converting my interior to black, debating on leaving the headliner and seats grey.
this is completely over kill for my engine but it was shiny and...I'll just leave it at that..lol
fully adjustable mechanical/vacuum advance with a built in rev limiter
comp XE262H cam and all the required parts for it
comp magnum 1.52 roller tip rockers
this should be a fun winter. |
RK82 Member
Posted: Fri Jun 14, 2013 12:13 pm Post subject: |
haven't updated this for awhile, I finished doing the cam swap.
but it didn't really have any more power than it did before. best pass before was a 15.35 at 88mph after it went 14.93 at 93 mph, shoulda known better the bottom end was done.
I also got sick of dragging the exhaust on every bump or dip in the road went back to a 3" single with a flowmaster 80
this was my first try at building a y-pipe
RK82 Member
Posted: Fri Jun 14, 2013 12:24 pm Post subject: |
my buddy had this 88 L98 sitting around, here it is after a good cleaning and paint
and in the car
best pass so far has been a 14.12 at 98 I haven't done any tuning yet the carb and distributor are still set up for the 305 |
Posted: Sun Jun 16, 2013 3:43 pm Post subject: |
Looking good! Keep up the great work!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Jun 16, 2013 6:12 pm Post subject: |
So did you scrap the other engine or put the new cam/springs/rockers in the L98? Cool looking car, just making sure I am following the progress here
RK82 Member
Posted: Sun Jun 16, 2013 8:51 pm Post subject: |
| Schultzy89GTA wrote: | So did you scrap the other engine or put the new cam/springs/rockers in the L98? Cool looking car, just making sure I am following the progress here
I put the cam/springs/rockers in the 305 drove it for probably 3 weeks then it started smoking really bad. I tore it down and found 3 broken rings, one piston was different from the other 7, and the two center main bearings were down to copper. The L98 is still stock |
Posted: Sun Jun 16, 2013 8:58 pm Post subject: |
Every time you re-up this thread I remember how much I like the look of this car.
Any reason the cam didn't make it into the new motor? |
Posted: Mon Jun 17, 2013 7:14 am Post subject: |
| aaron_sK wrote: | | Any reason the cam didn't make it into the new motor? |
I'm guessing the 305 was flat tappet and the L98 is roller. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Jun 17, 2013 12:02 pm Post subject: |
Got it. Thanks!
Looking good man.
RK82 Member
Posted: Mon Jun 17, 2013 6:07 pm Post subject: |
| Alphius wrote: | | aaron_sK wrote: | | Any reason the cam didn't make it into the new motor? |
I'm guessing the 305 was flat tappet and the L98 is roller. |
pretty much, I still have that whole cam kit, not sure what to do with it yet, its probably pretty hard to sell a used cam |
Posted: Mon Jun 17, 2013 6:08 pm Post subject: |
Makes sense.
If you keep the lifters matched someone will buy it. |
Posted: Mon Jun 17, 2013 6:27 pm Post subject: |
| Comp 262xe makes great power. Mine was fun until it went flat. |
Posted: Mon Jun 17, 2013 7:24 pm Post subject: |
Sold my 262XE cam with the lifters matched for like $75! _________________ A redline a day keeps the carbon away! |
