| What day will you be able to attend? |
| Friday the 22nd. |
71% |
[ 5 ] |
| Satarday the 23rd. |
28% |
[ 2 ] |
| Total Votes : 7 |
Posted: Wed Jun 20, 2007 3:52 am Post subject: |
Yeah, I always thought that rule was kind of stupid. We pretty much let it go on stock or near stock cars though. It would make more sense if it were for car that went xx.xx ET in the quarter or something along those lines. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
82camaro383 12sec Club
Joined: 11 Sep 2005 Posts: 117 Location: Pullman/Vancouver, WA
Posted: Wed Jun 20, 2007 11:21 pm Post subject: |
What time is everyone heading over. I am going over when the gates open. _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Fastest Time: 12.7sec @ 107mph |
Posted: Thu Jun 21, 2007 7:31 am Post subject: |
| Usually try to be over there about 7ish. |
Posted: Thu Jun 21, 2007 7:37 am Post subject: |
| i might not be there after all. i have a prior engagement, but i am going to see if i can make it. |
Posted: Thu Jun 21, 2007 7:46 am Post subject: |
| Xophertony wrote: | | i might not be there after all. i have a prior engagement, but i am going to see if i can make it. |
Posted: Thu Jun 21, 2007 8:27 am Post subject: |
I'll likely be heading over with paul, so I'll be there around 6 or 7pm. _________________
redlava Member
Posted: Thu Jun 21, 2007 7:21 pm Post subject: |
I didnt have enough time to set up the metal fuel lines . So I will probably just go, hang out and watch. |
Posted: Thu Jun 21, 2007 8:17 pm Post subject: |
| yeah, I'll be just watching too. I'm in for sure by the way. |
Posted: Thu Jun 21, 2007 8:29 pm Post subject: |
| Wha? Why just watching? |
Posted: Thu Jun 21, 2007 10:21 pm Post subject: |
Why both of you watch?
Red, if you read the above post from the tech there you should be fine.
Tony? RACE! |
Posted: Thu Jun 21, 2007 10:31 pm Post subject: |
The first few times I went to PIR I had too much rubber hose coming off my hard lines. All I got was a warning and told to fix it for next time. _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Posted: Thu Jun 21, 2007 11:18 pm Post subject: |
allright, I can't race all night though, the GF is coming with and i can't just leave her in the stands all night or she will get upset and then i will get no 'attention' later on that night.
i'll have to re-register.
ohhh... this means i'll be able to <STRIKE>beat</STRIKE> race chris.
EDIT*
so the forum says HTML works, but HTML code like "strike" does not seem to work. lame. |
STEEL Member
Posted: Fri Jun 22, 2007 1:57 am Post subject: |
Im not going to be able to get down there after all.... Truck needed a new battery, now I dont have money for gas....
Posted: Fri Jun 22, 2007 7:16 am Post subject: |
| Xophertony wrote: | allright, I can't race all night though, the GF is coming with and i can't just leave her in the stands all night or she will get upset and then i will get no 'attention' later on that night.
EDIT*
Your girlfriend can hang out with Brandy and possibly Megan. |
Posted: Fri Jun 22, 2007 8:53 am Post subject: |
pull a plug wire tony, then it'll be even.
Race of the Chevy V7's!!
Megan's gotta work until 5:30 tonight, she was sounding kind of iffy if she even wanted to go anyway. _________________
Posted: Fri Jun 22, 2007 10:46 am Post subject: |
to tell you the truth i am kinda scared. when i first started racing the GTA it had a tourque converter, plenty of give there. then it got a centerforce, no more give. but i still had shitty tires.. now i have nittos.. no more give, just hook. i am a little scared for my trannsmission.. but if Rodney can run slicks i supose i can run nittos.
::knocks on wood:: |
Posted: Fri Jun 22, 2007 11:19 am Post subject: |
Your transmission should be fine. My friend runs nittos on his fox body mustang with a stock 5 speed and 347 stroker. He has never had any problems. _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Posted: Fri Jun 22, 2007 12:00 pm Post subject: |
| 82camaro383 wrote: | | Your transmission should be fine. My friend runs nittos on his fox body mustang with a stock 5 speed and 347 stroker. He has never had any problems. |
maybe.
While the Tremec (ford) T-5's, and the Borg Warner (GM) T-5's were both rated to 300ft lbs, they seem to last longer than were than the Borg Warner (GM) T-5's. Plus the Tremec's have a "straight in" mounting design, while the Borg Warner for 3rd gen's have a 18 degree offset angle. They say the Torque arm design puts extra load on the transmission which causes the input bearings to fail, and thus chuck 1st gear out the side of the case.
I know more guys who have put 400+ ft/lbs through a Stock Tremec T-5 in the foxbody and have had it take the punishment, than guys who've put 400+ ft/lbs on the Borg Warner unit and had it hold.
Tony, your tranny should be fine.I know You've raced before on the T-5 in that thing...last August/Steptember? _________________
Posted: Fri Jun 22, 2007 12:05 pm Post subject: |
with cooper cobras, my point was the tires would break loose before, these nittos are sticky, but i have spun em before without blowing parts all over the ground...
Posted: Fri Jun 22, 2007 12:34 pm Post subject: |
Almost stock L98. (tony) vs Modded 350 (rodney).
You'll be fine tony. If you broke it, it's because something else was wrong.
PS Rod didn't launch hard on the slicks and had clutch slip. |
