T56
Goto page Previous  1, 2
PostPosted: Thu Dec 01, 2011 9:28 pm    Post subject: Reply with quote
See Aaron, you think you had perfect timing in mentioning that after he finished, but in truth my heater is blowing ice cold. Smile
Killing mailboxes since 2009
PostPosted: Thu Dec 01, 2011 9:41 pm    Post subject: Reply with quote
Well then by definition it's not a heater now is it?
And when are you two going to get that car done? Just because none of the junkyards around here have the right ECM/harness. Razz
PostPosted: Thu Dec 01, 2011 9:44 pm    Post subject: Reply with quote
Al Hasse wrote:
Had to have heater core replaced
Should have brought it out here Al. Would have been peanuts for me after the Volvo. Laughing
It wouldn't have made it that far. Couldn't see where I was going as it was Shocked Inside the car was fogged up before I started that morning...
PostPosted: Fri Dec 02, 2011 6:48 am    Post subject: Reply with quote
Car is back together and home. Ran like crap, hard to start was backfiring through the intake under load, missing when accelerating etc.
new cap, rotor and wires. timing is good new coil etc. only known problem was a 350 prom running a 305 engine. send that prom back waiting on a 305 to show up. Didnt make much sense to ignore that known problem and troubleshoot around it.
PostPosted: Fri Dec 02, 2011 8:38 am    Post subject: Reply with quote
Re read what I said about the ls trans.
nonsensekid20
PostPosted: Fri Dec 02, 2011 12:02 pm    Post subject: Reply with quote
http://www.mcleodracing.com/products/Transmission+Adapters.mcl
Which one?
http://seattle.craigslist.org/see/pts/2731906514.html
Good price?
And what do I do about the torque arm?
PostPosted: Fri Dec 02, 2011 12:16 pm    Post subject: Reply with quote
Overpriced.
Maybe $1300 for a rebuilt one. With the steel fork.
8-207
Damn they went up. LOL Used to be about $225.
It'll come with a bearing retainer and hardware. Bolts to your bell housing. Everything in your bell housing stays the same.
You should be able to use a 4th gen torque arm mount.
nonsensekid20
PostPosted: Fri Dec 02, 2011 3:12 pm    Post subject: Reply with quote
http://www.ebay.com/itm/REAR-AXLE-TORQUE-ARM-USED-1982-2002-CAMARO-/150694905946?hash=item23161dc85a&item=150694905946&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
82-02... Confused
PostPosted: Fri Dec 02, 2011 3:31 pm    Post subject: Reply with quote
82-02... Confused
Just the mount which attaches to the tail shaft.
http://www.ebay.com/itm/98-02-CAMARO-FIREBIRD-3800-TORQUE-ARM-MOUNT-DAMPNER-/120714832116?hash=item1c1b2a28f4&item=120714832116&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
PostPosted: Fri Dec 02, 2011 3:33 pm    Post subject: Reply with quote
There is no such thing as an 82-02 torque arm.
That mount is from a veesix fourthgen.
Use your existing torque arm and use the torque arm mount from the T-56 you buy. Simple as that.
PostPosted: Fri Dec 02, 2011 3:36 pm    Post subject: Reply with quote
Or mount it off the tail shaft
PostPosted: Fri Dec 02, 2011 3:38 pm    Post subject: Reply with quote
That is where the mount goes, Al. Laughing
Did you mean crossmember?
PostPosted: Fri Dec 02, 2011 4:10 pm    Post subject: Reply with quote
I think you know what I meant, but let me fix it anyway...
"Or mount the torque arm off the tail shaft with a cross member." Razz
nonsensekid20
PostPosted: Fri Dec 02, 2011 4:24 pm    Post subject: Reply with quote
Hahaha I know there's no such thing, that's why I was confused. OH. my bad. Sorry I thought you meant I needed the whole torque arm.
And this may be a dumb question, but what's the dampner for?
I saw one on ebay for like 1300. Didn't look like it had the steel fork. I have to save up money anyway so I'll keep a lookout. Maybe just start buying parts piece by piece.
PostPosted: Fri Dec 02, 2011 4:34 pm    Post subject: Reply with quote
It's for the catalytic converter mount.
nonsensekid20
PostPosted: Fri Dec 02, 2011 5:42 pm    Post subject: Reply with quote
I don't have cats. And if I'm bolting my old bellhousing to the tranny, why do I need the steel fork with the t56? Do I have the wrong part in mind?
PostPosted: Fri Dec 02, 2011 7:02 pm    Post subject: Reply with quote
3-4 fork not clutch release fork! Laughing
nonsensekid20
PostPosted: Fri Dec 02, 2011 7:17 pm    Post subject: Reply with quote
Lol. See that's why I asked. That's the fork I thought he was talking about and evidently, it's not. Laughing
Page 2 of 2
