Posted: Fri Sep 23, 2011 9:18 pm Post subject: |
| Everything moves around when you drive. A hard foul of adjacent parts is a no-no. Stress cracks and longevity issues. Something will give eventually. I'm more concerned about the plastic mounting rail for the fans than the fans themselves. |
Posted: Fri Sep 23, 2011 9:30 pm Post subject: |
| aaron_sK wrote: | Bar doesn't move enough to shove the fans. What is the worry here?  |
What is the issue. I have been running GW for years. They touch the fan mounts. No big.
Posted: Fri Sep 23, 2011 9:48 pm Post subject: |
| The problem is you have a metal bar in contact with a plastic part and both move in different directions. When things aren't right you end up playing a game of statistics. Not everybody will have problems, but some people will. One thing I know for sure is I won't have a problem if the parts aren't touching. That's the route I want to take. |
Posted: Fri Sep 23, 2011 10:05 pm Post subject: |
Dude, there isn't a lot of movement here.
Last edited by Schultzy89GTA on Sat Sep 24, 2011 11:18 am; edited 1 time in total |
Posted: Fri Sep 23, 2011 10:09 pm Post subject: |
I have found the plastic that GM used to be very resilient.
Mike, is the fitment better with the TDS bar vs. the GW bar? Or did you have a single fan on the '88 GTA? |
Posted: Fri Sep 23, 2011 10:13 pm Post subject: |
| FWIW; I've got the TDS bar and dual fans. I think I remember having to chop the swaybar bracket alignment tab off or down or something but it doesn't hit my fan shroud. |
Posted: Fri Sep 23, 2011 10:17 pm Post subject: |
Can't recall on the TDS bar bud. It was on there when we got it. The '88 was dual fan just like my '89.
This is a brace. Not like it is a sway bar (aka 'spring') and moving around. The 'feet' on the dual fans is pretty heavy plastic. No wear, no discernible movement.
Last edited by Schultzy89GTA on Sat Sep 24, 2011 11:19 am; edited 1 time in total |
Posted: Fri Sep 23, 2011 10:19 pm Post subject: |
The reason I ask is that I have that used TDS bar kicking around here still and as such I'd be totally willing to trade Jon for his GW unit if this is going to be a big conniption.
I am running an aftermarket aluminum radiator and will probably run a Taurus fan I've had sitting on the shelf forever. Plus I don't care about stuff touching other stuff because I just want to drive fast in a Camaro.  |
Posted: Fri Sep 23, 2011 10:22 pm Post subject: |
hehe
One way to find out
Last edited by Schultzy89GTA on Sat Sep 24, 2011 11:20 am; edited 1 time in total |
Posted: Sat Sep 24, 2011 1:04 am Post subject: |
Jon, You should have no problems with a little rub there. As stated, its a brace so there is only minor flex of the chassis itself. No more than say your dash rubbing on the console.
I had a factory wonderbar, so it wasn't an issue, but I definitely wouldn't have worried if the fans contacted it.
-P _________________ A redline a day keeps the carbon away! |
Posted: Sat Sep 24, 2011 7:29 am Post subject: |
| Jon, I am sincere in my offer to trade you bars. If you are interested send me a PM with details on what exactly you want me to measure and I can get detailed photographs so we can determine if the TDS bar will work for you. |
Posted: Sat Sep 24, 2011 11:23 am Post subject: |
Edited the thread to keep content but remove remarks considered offensive. Apologies to those who made popcorn.
Posted: Sat Sep 24, 2011 12:07 pm Post subject: |
I have clearance now. Solved.
Aaron - As always, thank you for the info. It helped me know what are my options so I could decide what to do. Apology was meaninful, too. Thanks.
Ian - Ya, I had problems with alignment tab too but in my case I was able to flip the brackets and resolve it.
Shultzy - I know you tried hard but unfortunately you didn't make the cut for the CC cheerleading squad. Now go take a nap, grumpy bear. |
1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Sat Sep 24, 2011 12:58 pm Post subject: |
| Alphius, what do you think of the TDS bar? I'm looking into buying one because it's a fair price and my front end feels pretty loose. |
Posted: Sat Sep 24, 2011 2:45 pm Post subject: |
| QwkTrip wrote: | I have clearance now. Solved. |
So what was the solution? |
Posted: Sat Sep 24, 2011 2:46 pm Post subject: |
| aaron_sK wrote: | | QwkTrip wrote: | I have clearance now. Solved. |
You saw away the offending plastic so that it doesnt crack..  |
Posted: Sat Sep 24, 2011 5:47 pm Post subject: |
Glad you guys are getting along again!
James - Why do you post such inflamitory things?!?!?!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Sep 24, 2011 6:56 pm Post subject: |
| 1987_sportcoupe wrote: | | Alphius, what do you think of the TDS bar? I'm looking into buying one because it's a fair price and my front end feels pretty loose. |
The TDS wonderbar is great. It has tons of clearance for the dual fan setup, and is the only wonderbar that has a bolt pattern that fits both '82-'83 cars and later cars. Not that that matters too much for you and I...
Make sure your suspension is in good shape. If it feels loose without a wonderbar, something is probably wrong. Mine felt fine pre-bar, but just felt better post-bar. It's not something I would have noticed and said "I think my suspension feels crappy" or anything.
I noticed a lot more solidity when taking corners hard and fast with mine on. I drove the same road after installing and the car felt a lot more planted. I would love to see a slow motion video of hard cornering and its effects on the front suspension and frame rails, since I totally was not expecting it to make a noticeable difference at all. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sat Sep 24, 2011 8:09 pm Post subject: |
Just FYI, I just installed a TDS wonder bar on Thursday and had absolutely no clearance issues with the factory dual fan setup on my '91. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Sep 24, 2011 9:43 pm Post subject: |
| Ok. I feel like my suspension is in decent shape I just want to upgrade and have a tighter more planted cars. The iroc sway bars with energy bushings already made a huge difference so I'm just continuing to upgrade. |
