Posted: Mon Aug 22, 2011 9:15 pm Post subject: |
Mmkay, so adtimtedly I'm a little drunk, but this is really starting to look like a good idea...
See the Northern tool box will save weight, which is good.
But seriously now, I've not been real happy with the Trans Am dash in the Camaro. The issue I have is that the gauges are too low for me, and there's still not enough real estate for all I want to do. I'm thinking maybe a sheet of aluminum or something and make a single bend on it with a brake. Then bolt it to the stock mounts. I can run the factory defrost vents (opnly part of the hvac I'm keeping anyhow). I'll have to figure out what to do about the head unit though. No center console in this car. |
Posted: Mon Aug 22, 2011 9:22 pm Post subject: |
I can't say I've seen any sheet metal dash ever look good...
Good luck!  |
Posted: Mon Aug 22, 2011 9:23 pm Post subject: |
| I like the cardboard. Every time a cop pulls you over and asks if you know how fast you were going just tap on the cardboard and say, Yep! 88 MPH. |
83Z28BlackBetty Bam-Ba-Lam
Posted: Tue Aug 23, 2011 3:03 pm Post subject: |
You better do something about that dash before you find yourself getting zapped into the future. _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Tue Aug 23, 2011 3:51 pm Post subject: |
| also ditch that wheel in favor of the base model firebird wheel. |
Posted: Tue Aug 23, 2011 4:04 pm Post subject: |
| The guy whp pianted my car did for two hundred bucks. Was almost as cheap if I took into how many cans of rattle can it would have been, but a much better paint job. |
Posted: Tue Aug 23, 2011 4:20 pm Post subject: |
| Xophertony wrote: | | also ditch that wheel in favor of the base model firebird wheel. |
IROC wheel. But yes, base Camaro wheel brings the suck.
I think I'll probably still go with the GTA dash, I'll just have to fiddle with it. Nothing ever good enough for me.  |
Posted: Tue Aug 23, 2011 5:43 pm Post subject: |
I am solving the yellow problem from the inside out!
I am certain Al will recognize my new rims.  |
Posted: Tue Aug 23, 2011 5:49 pm Post subject: |
| aaron_sK wrote: | I am certain Al will recognize my new rims.  |
Nice improvement How's the paint holding up on them? |
Posted: Tue Aug 23, 2011 6:01 pm Post subject: |
| Everybody knows a banana's white inside the peel... |
Posted: Tue Aug 23, 2011 7:25 pm Post subject: |
| Al Hasse wrote: | Nice improvement How's the paint holding up on them? |
Very well, Al. Especially considering that neither I (nor my Dad when he had them) ever cleaned or did anything with them.
| chevymad wrote: | | Everybody knows a banana's white inside the peel... |
Tru dat. But this banana is going to get real rotten real fast.  |
Posted: Tue Aug 23, 2011 8:12 pm Post subject: |
Man, you move quick! All I did tonight was look at wires coming out of C100 connector and put some yellow and green highlighter on paper. It's like a 1000:1 ratio of progress.  |
Posted: Tue Aug 23, 2011 8:21 pm Post subject: |
| QwkTrip wrote: | | Man, you move quick! |
The impetuousness of youth combined with a somewhat marginalized employment situation.  |
Posted: Tue Aug 23, 2011 11:28 pm Post subject: |
Im starting to think you just like to lock your self in your garage with a few cans of paint all day for the fumes.  |
Posted: Wed Aug 24, 2011 6:50 pm Post subject: |
| aaron_sK wrote: | | Xophertony wrote: | | also ditch that wheel in favor of the base model firebird wheel. |
Ugh! The stock IROC steering wheel brings the suck second only to the base Camaro wheel! They are both fugly!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Aug 24, 2011 6:53 pm Post subject: |
Wiring looked pretty clean really. And Amplifier wire can handle a lot more current than battery cable for the same size or smaller. _________________ A redline a day keeps the carbon away! |
Posted: Wed Aug 24, 2011 6:55 pm Post subject: |
| fiveoformula wrote: | Im starting to think you just like to lock your self in your garage with a few cans of paint all day for the fumes.  |
Blargh! I hate paint fumes.
| blue89 wrote: | | Nice progress! When does the cage go in? Can't have a sheetmetal dash in a t-top without a cage. |
Haha, no funds for that now. I would love to run a cage and tie it into the strut towers and SFC's, but as they say, your money's money is all that moneys.
| RSFreak wrote: | Ugh! The stock IROC steering wheel brings the suck second only to the base Camaro wheel! They are both fugly!  |
Says the guy who likes airbag wheels! I will probably be looking at a Grant down the road, but I have the IROC wheel in hand.
| Twilightoptics wrote: | | Wiring looked pretty clean really. And Amplifier wire can handle a lot more current than battery cable for the same size or smaller. |
Looked being the operative term. The car cranked so slow it would barely start. That whole install was bad-news bears. |
Posted: Wed Aug 24, 2011 6:58 pm Post subject: |
I have a thirdgen roll bar hoop just sitting at the house in tacompton with no home... It could be yours for cheap!  |
Posted: Wed Aug 24, 2011 7:08 pm Post subject: |
| aaron_sK wrote: | | Twilightoptics wrote: | | Wiring looked pretty clean really. And Amplifier wire can handle a lot more current than battery cable for the same size or smaller. |
Welding cable is the way to go. Handles lots of current and is super flexible - more so than amplifier wire or battery cable of the same gauge, and its insulation is like armor. My positive cable is welding cable, had it made when my amplifier wire cable got too close to the exhaust manifold and got real brittle. I think I'll have my installer friend make a complete set for my 89 when I replace the battery. |
