The ultimate dilemma
Goto page Previous  1, 2
KatsCam
PostPosted: Fri Apr 08, 2011 11:25 am    Post subject: Reply with quote
blue89 wrote:
Go big block. Quick screwing around. You know you want one.
That's two votes for the motor, Jake! Razz
PostPosted: Fri Apr 08, 2011 4:07 pm    Post subject: Reply with quote
my GTA used to be an auto, even in stop/go traffic i prefer the stiff ass clutch and "power tower" Pro 5.0 shifter to the slushbox
PostPosted: Fri Apr 08, 2011 5:28 pm    Post subject: Reply with quote
Hmm Cost? T5 is definitely cheaper.....
I don't know the going rate but here is what I did for T56:
LS1 T56 - $1100
McLeod Adapter Plate - $250
McLeod Pilot - $50
Everything else is thirdgen specific. Get a torque arm/crossmember from Spohn.
Get your driveline shortened or lengthened depending on which setup you have now.
Bellhousing, clutch, pedals, hydraulics, fork, flywheel, etc are all thirdgen specifc.
If you go LT1 style you need a more expensive clutch, more expensive flywheel specific to a 2 piece rear main engine but an LT1 trans.
Speedometer is an issue. T56 is only VSS. See if Alloy is still doing a conversion to run a speedo cable.
Otherwise TKO is $2200 and you need all the same thirdgen specific stuff to bolt it in, and a custom crossmember/torque arm relocation like the spohn one. But the TKO will run a speedometer cable.
PostPosted: Fri Apr 08, 2011 11:06 pm    Post subject: Reply with quote
I can't imagine what a gutless POS my 2.8L would be without the T5. Go for the manual tranny. Wink
PostPosted: Sun Apr 10, 2011 12:29 pm    Post subject: Reply with quote
91RSVert wrote:
I will say IMO it blows ass to be shifting gears all the time, and having to sit on the clutch and brake at a stoplight.
Who keeps their foot on the clutch? Ever heard of neutral? Laughing
PostPosted: Sun Apr 10, 2011 6:41 pm    Post subject: Reply with quote
I'm with stupid
Not good for the hydros or the TOB to be sitting compressed like that all the time either.
Also, between a first-gen SBC build or a T5 swap I would like to cast my vote for none of the above. Get a damn LSx/LQx or do something completely crazy (ahem Cool).
PostPosted: Mon Apr 11, 2011 8:30 am    Post subject: Reply with quote
Ideally you'd find an LS1/T56 combo. Solve both your dreams.
PostPosted: Mon Apr 11, 2011 9:03 am    Post subject: Reply with quote
Texas seems to be the land of milk and honey for used, built LS engines for sale.
PostPosted: Tue Apr 12, 2011 6:45 am    Post subject: Reply with quote
my little sister had an 89 firebird, 2.8L/Auto combo. was the slowest car i have ever driven. it could do a standing "powerbrake" with the one tire though. Laughing
Page 2 of 2
