My 82 T/A
RK82
1982 Pontiac Trans Am
PostPosted: Fri Jan 20, 2012 9:39 pm    Post subject: Reply with quote
pick up some Eibach sportlines off criagslist, they should be a bit better than the cut stock springs
also found a set of SP performance diamond slotted rotors, not a big fan of the slots but they were cheap. might try a set of Hawk Performance HPS brake pads
there alittle rusty from sitting in a barn for a few years
RK82
PostPosted: Fri Jan 20, 2012 9:46 pm    Post subject: Reply with quote
found out last year before I parked it my fuel pump was putting out 8psi and over powering the needle and seat in the carb, I've slowly been working on putting in a dead head regulator. I might have got a little carried away with AN fittings and braided line...LOL
PostPosted: Sat Jan 21, 2012 9:22 am    Post subject: Reply with quote
Nice carb. What body and boosters are they?
PostPosted: Sun Jan 22, 2012 8:52 pm    Post subject: Reply with quote
HVAC delete in Canada... that's pretty hardcore. Yup yup
Was the FPR mounted on the fender for any reason? Seems like you could build a bracket off the alt mount or something and run less fuel line sort of like so....
RK82
PostPosted: Sun Jan 22, 2012 9:57 pm    Post subject: Reply with quote
ya that was a mistake, I go throw a few bottles of rain-X anti-fog a year and freeze my ass off when its cold out.
never thought of putting it there, the fender seemed like a good place
RK82
PostPosted: Sun Jan 22, 2012 10:20 pm    Post subject: Reply with quote
just a holley 4160 with choke horn milled off
RK82
PostPosted: Fri Feb 17, 2012 8:07 pm    Post subject: Reply with quote
got the sportlines in, hopefully it settles a bit more.
PostPosted: Fri Feb 17, 2012 8:08 pm    Post subject: Reply with quote
Must be a light car in the front end, if it has that stance with sportlines!
RK82
PostPosted: Sun Feb 19, 2012 7:48 pm    Post subject: Reply with quote
that's what I figured the cars pretty light it weighed 3190 before the frame connectors and traclink.
RK82
PostPosted: Sun Feb 19, 2012 7:54 pm    Post subject: Reply with quote
I picked up a holley 4150 street avenger, I haven driven it that much but it seems alot better than the 4160 single feed I had before.
PostPosted: Sun Feb 19, 2012 7:59 pm    Post subject: Reply with quote
I got Eibacks on the front of the Berlinetta and it still sits too high in my opinion. But I only have about 2" of ground clearance with my current exhaust setup so I'm not going any lower with it.
PostPosted: Sun Feb 19, 2012 10:52 pm    Post subject: Reply with quote
That's quite an accomplishment for a streetable smallblock car. Thumbs up
If your old 4160 had plate secondaries I would imagine you would notice a whole world of new power. Cool
RK82
PostPosted: Mon Feb 20, 2012 8:49 pm    Post subject: Reply with quote
I'll have to weigh it again this summer, I think I've added 100-150 pounds to it
RK82
PostPosted: Thu Feb 23, 2012 5:40 pm    Post subject: Reply with quote
picked up some IROC wheels
the front two are BFG G-force sports with around 80% left, the rear two are getting replaced with Nitto NT555s
PostPosted: Thu Feb 23, 2012 5:54 pm    Post subject: Reply with quote
Now you guys make fun of me for having mud flaps on my car... but look! I'm not the only person!
I'm just way ahead of my time. You'll all be doing it soon enough.
PostPosted: Thu Feb 23, 2012 6:02 pm    Post subject: Reply with quote
Base birds and formulas mud flaps are almost required. I tried to go without after painting it the first time.. hello rockchips. If I had gfx they'd serve the same function.
PostPosted: Thu Feb 23, 2012 6:40 pm    Post subject: Reply with quote
IROCs make everything look good, it is a fact. Good choice on wheels. Wink
PostPosted: Thu Feb 23, 2012 11:16 pm    Post subject: Reply with quote
Yup! Cool
RK82
PostPosted: Thu Mar 08, 2012 7:42 pm    Post subject: Reply with quote
my nitto NT555Rs came in last week, mounted them up today
RK82
PostPosted: Wed Apr 11, 2012 12:54 pm    Post subject: Reply with quote
Since I don't daily drive this car anymore, I figured I'd get rid of the crappy 2 1/2" single exhaust.
here's the old exhaust
The new set-up is literally a hack job I cut up the old exhaust to make this, all I had to buy was two 18" long 2 1/2" straight pieces and mufflers, I am gonna add a crossover pipe eventually
I went with moroso spiral flow mufflers, there a little loud but they sound good
I have alot more tuning to do but it seems to pull alot harder from 3000-6000RPM
Page 2 of 3
