Posted: Thu Jan 02, 2014 6:02 pm Post subject: |
| Twilightoptics wrote: | | Then you need more pushups!!! |
This is true, however I still prefer to use a jack!  |
Posted: Thu Jan 02, 2014 6:59 pm Post subject: |
| RSFreak wrote: | | Twilightoptics wrote: | | Then you need more pushups!!! |
Some reason that brings this to mind. http://youtu.be/L3fP18gIoAY |
RoosterC Member
Joined: 24 Feb 2011 Posts: 43 Location: Federal Way, WA
1988 Chevrolet Camaro
Posted: Sun Jan 05, 2014 6:32 pm Post subject: |
What year is the tilt column out of?
Also, how are the pins holding together? I would hate to go through with the install and have it wiggling about _________________ Sink or Swm |
Posted: Sun Jan 05, 2014 6:47 pm Post subject: |
Jeremiah took the column. I don't know if he was going to sell it or use it, so you'll have to ask him. In case he is selling it I will answer your questions:
1) The column is from an '85. Pulse wipers, no cruise control, manual trans lockout.
2) I have never seen a tilt pin failure in a GM column.
3) I rebuilt the column awhile back and never used it, so the tilt plate has been reinstalled properly, guaranteeing you will have no wobble issues. This column is actually the one I used to write the tutorial that is in the Garage forum. The lock cylinder is also brand new. |
Posted: Tue Jan 07, 2014 10:27 pm Post subject: |
| I am definatly gonna use it. It is so smooth . It is a worj of art |
