Mmm.... greeeeen...
Goto page Previous  1, 2, 3, 4, 5, 6
PostPosted: Wed Oct 31, 2012 1:07 am    Post subject: Reply with quote
That is looking pretty schnazzy! When do you think you will key on that bad boy?
PostPosted: Thu Nov 01, 2012 3:20 pm    Post subject: Reply with quote
Eh, probably not for a while. I'm 99% sure I'll need an oil pump for the turbo. I effed up big time by mounting the turbo too low and the drain hose comes out of the turbo with a 45* fitting and is just about level going into the timing cover. If I wanted to pull the motor to weld a bung in the pan I could go without but I'll just pick up a pump. Basically just need to buy that and a tune session to delete the MAF in the PCM and I'm good to go.
I'm not going to worry about ducting the radiator completely until I get it tuned and find a base model hood to chop up.
PostPosted: Thu Nov 01, 2012 4:34 pm    Post subject: Reply with quote
You want a base model or another vented transam hood? I still have that transam hood... cheap cheap.. you move. Laughing
PostPosted: Thu Nov 01, 2012 8:42 pm    Post subject: Reply with quote
I want a base hood! Which is difficult because nobody else thinks they're worth anything so they get tossed! The TAs front vents are halfway into where I will have the radiator ducting exit...
PostPosted: Sat Nov 03, 2012 10:22 am    Post subject: Reply with quote
Maybe I missed it, but your going to be making your good vented? Now that I think about it I seem to remember you popping in a thread on this topic on TGO awhile ago. If so I'm pretty interested to see how it turns out.
Page 6 of 6
