Edelbrock E street heads
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon May 09, 2016 5:30 pm    Post subject: Reply with quote
So it really only stalls the advertised rpm from a dead stop at WOT?
PostPosted: Mon May 09, 2016 6:47 pm    Post subject: Reply with quote
That's pretty much how it works. In fact you'll only get the advertised stall number for the specific amount of torque the converter is rated for. If you have more torque that converter will actually stall higher. That's how you can go to the junkyard and pick up a v/6 converter and have yourself a cheap mild stall converter.
But a good converter won't feel loose/sloppy just driving around.
Just came in from removing the timing cover again. Guess what? It quit leaking LOL But I guess it will be done right this time. I was also comparing the old seal to the new one and looks like last time I built this motor I used the wrong seal as well. I even took a timing cover off an LO3 to compare and mine is the same. So definitely should have been using the thick seal. Might be real fun to get in there though.
PostPosted: Mon May 09, 2016 10:29 pm    Post subject: Reply with quote
Are you considering this for your truck? Vehicle weight plays a big role in stall behavior. There's a definite science to it, it's not just a hard and fast number on the tin.
PostPosted: Wed May 11, 2016 9:51 am    Post subject: Reply with quote
Definitely. That's why any reputable converter maker wants to know EVERYTHING about your build, weight, power, torque, cam, engine, transmission, gear ratio, name of your first born, how many times you pee at night.
PostPosted: Wed May 11, 2016 1:22 pm    Post subject: Reply with quote
Actually looking for a good stall for the thirdgen, going LS, I have an aluminum 5.3 and 4L65E, I know I'll probably get crap for going auto, but I have my reasons.
1. T56s are expensive
2. Don't want to mess with making the T5 work
3. I dont hate automatics, especially when 90% of my driving is in town
PostPosted: Wed May 11, 2016 2:49 pm    Post subject: Reply with quote
Hey man, you do you. Autos are fine too.
What cam will you run?
PostPosted: Wed May 11, 2016 3:26 pm    Post subject: Reply with quote
At minimum I'll run a LS6 cam, but maybe something bigger.
Any suggestions?
PostPosted: Wed May 11, 2016 4:23 pm    Post subject: Reply with quote
Ls use different converters as well. Damn.. no sale. LOL
PostPosted: Wed May 11, 2016 5:12 pm    Post subject: Reply with quote
Auto makes sense for a highway cruiser or a stoplight racer so if that's what you're after it makes perfect sense.
...Plus the 65 is much less of a pile than the 700. Smile
A T-56 is annoying to drive with as well as costing you your left nut.
PostPosted: Wed May 11, 2016 5:17 pm    Post subject: Reply with quote
Lol sorry. Hijacking your thread for nothing!
So I already have a converter, but the stall speed is a mystery. I got it from a local guy who seems pretty honest, and he said it flashed 2800rpm in his 66 Chevy pickup with a stock 5.3, he took out because he blew the 60e and went to a 4L80E.
I took the converter to a place in Portland that rebuilds them, he cut it open and he told me he thinks it's stock. So I don't know who to believe. He didn't seem to do much with performance oriented stuff.
PostPosted: Wed May 11, 2016 5:23 pm    Post subject: Reply with quote
I want to cruise it everywhere really. And never complain about being stuck in traffic.
Also excited that it's computer controlled so I can dial it in to my liking.
PostPosted: Sat May 14, 2016 4:38 pm    Post subject: Reply with quote
Got the motor back together. Lifted the car and pulled the trans out to replace the converter. I'll give a recommendation for harbor freights cheap trans jack. Its just a screw/scissor jack without tilt adjustments but works really slick so far with the auto. Also got it 25% off on mothers day. Very Happy
Doing a little governor change on the trans when its down. Hopefully, I'll get it to downshift.
Went to put new converter into the trans and realized that I have the opportunity to replace the TCC checkball that the ATSG book had me remove when I built the trans. So I came in the house to research whether I should put it back or not. Looks like I should, without the checkball the tcc will lock up instantly. This may be why I noticed the stall converter so much when the tcc locks. Dana at probuilt also mentioned that its hard on the damper springs.
Sooo... looks like I wait til Tuesday for a new capsule to arrive before I can start putting everything back.
PostPosted: Sat May 14, 2016 4:47 pm    Post subject: Reply with quote
That HF trans jack is fantastic. I used mine for about nine years and I wasn't exactly nice to it. I forget who ended up with it, Paul maybe?
PostPosted: Sat May 14, 2016 7:09 pm    Post subject: Reply with quote
Quality may have gone downhill, I have one from a year or two ago and it blew out the screw retaining mechanism the second time I used it. I managed to booger it back together to finish the job, but it doesn't work very well anymore.
PostPosted: Sat May 14, 2016 9:44 pm    Post subject: Reply with quote
Not I.
Harbor Freight + Quality = Oxymoron
They couldn't even do fuses right!
PostPosted: Sun May 15, 2016 10:19 am    Post subject: Reply with quote
Hmm... must have gone to Jeremiah or something. Laughing
Harbor Freight does get it right sometimes. I'm still running their aluminum floor jack after six-ish years without a single issue. I also think they have the best price:quality ratio for nitrile gloves.
PostPosted: Fri May 27, 2016 7:06 pm    Post subject: Reply with quote
I seriously can't win. Still has a leak. Still won't quite idle. New Trans governor messed up.the shifts, but did cure the shift down problem. But worst of all, the new converter vibrates severely between 35 & 4500 rpm. It's fine cruising and suddenly smooths out over 4500 rpm. Something definitely wrong with it.
PostPosted: Tue May 31, 2016 5:08 pm    Post subject: Reply with quote
Summits sending a new converter.. However, they say "within the next 2 days have the old converter ready for pickup" So.... guess I go out and try to pull the transmission tonight. Laughing
PostPosted: Tue May 31, 2016 7:10 pm    Post subject: Reply with quote
And its out.. Even got an hour of weed eating in afterwards. These cars are so simple sometimes. Smile
PostPosted: Tue May 31, 2016 7:32 pm    Post subject: Reply with quote
That was quick. Sucks when something like that happens. Don't ask me about the time I pulled the engine on a Subaru three times in two days to try to fix a leaking input shaft seal...
Page 6 of 8
