turbo_jimi Member
Posted: Mon Feb 25, 2013 8:28 pm Post subject: Carbed Vortec 350 |
Doing some research on this setup and would like to know what you all think...good, bad, indifferent. Appreciate any input.  _________________
Posted: Mon Feb 25, 2013 9:11 pm Post subject: |
How do you feel about a Vortec 350 injected?
So your actual question is:
Carb or FI.........? _________________ A redline a day keeps the carbon away! |
turbo_jimi Member
Posted: Mon Feb 25, 2013 9:45 pm Post subject: |
Just carb for now. _________________
83Z28BlackBetty Bam-Ba-Lam
Posted: Mon Feb 25, 2013 9:55 pm Post subject: |
Isn't that basically what Chris had in the Hello Kitty car? They will make some pretty decent power for cheap.
Good points: roller cam motor
vortecs are better heads than l98 TPI heads
put a small zz4 or hot cam in for a little more power through higher RPM
if you get the heads ported/polished with bigger valves they would be awesome budget heads
Bad Points : CARBURATOR...nuff said
you have to get a different timing cover since the timing cover has a big hole in it for the cam/crank sensor
you need an electric fuel pump since they don't have a mechanical provision _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Mon Feb 25, 2013 10:17 pm Post subject: |
My 383 is a Vortec TBI motor. I didn't ask for anything special when it was built, so stock 350 as far as I know, except for the bottom end. With fuel pressure bumped to 18psi, it dynoed 248 hp, 348 ft/lb. _________________ 92 Camaro
Posted: Mon Feb 25, 2013 10:51 pm Post subject: |
James is this an old 350 with Vortec heads on it or a Vortec truck motor with a carb on it?
How local is this kid? Can we run out and take a look at it sometime?
I think the crew might need a little more info on your insider scam so they can give advice.  |
turbo_jimi Member
Posted: Tue Feb 26, 2013 7:32 am Post subject: |
No scam, Aaron. I know what I want and what I'm getting into...
Just curious about the set up. Once in my possession, I'll pull all of the numbers to see what's really there. For all I know, it could be a 307.  _________________
Posted: Tue Mar 05, 2013 9:22 pm Post subject: |
Didn't some of the Truck Vortec SBC's not have the hole in the timing cover?
Either way, a Good, well tuned carb, a Good distributor/Coil and ignition box, and a good dual plane manifold will give a lot of pep to a mildly built bottom end, reguardless if its a flat-tappet or roller motor.
my humble .02 |
Posted: Thu Mar 07, 2013 12:23 pm Post subject: |
Turned out to be an L03 with a carb.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Mar 07, 2013 2:09 pm Post subject: |
Well thats a let-down... _________________
'88 FORMULA |
turbo_jimi Member
Posted: Thu Mar 07, 2013 2:24 pm Post subject: |
yeah, it is what it is...not super suprized, but at least it runs. _________________
Posted: Thu Mar 07, 2013 4:01 pm Post subject: |
| Looks pretty good in the pics, does it need alot? |
turbo_jimi Member
Posted: Thu Mar 07, 2013 4:19 pm Post subject: |
| fiveoformula wrote: | | Looks pretty good in the pics, does it need alot? |
Yes. Carb rebuild, mufflers, interior work, paint, electrical, among other things. I doubt I'll bring it to dyno unless I still have it next year. _________________
Posted: Thu Mar 07, 2013 5:35 pm Post subject: |
| Do you need a 4 bolt 350 rebuilder? |
turbo_jimi Member
Posted: Thu Mar 07, 2013 6:43 pm Post subject: |
| chevymad wrote: | | Do you need a 4 bolt 350 rebuilder? |
Are you talking about another engine. Not really. I have one that's been sitting in my shop for over 3 years.  _________________
Posted: Thu Mar 07, 2013 8:16 pm Post subject: |
| Lol.. ok. One of mine i've had since before I could drive. Was thinking maybe its time to get rid of it. |
turbo_jimi Member
Posted: Thu Mar 07, 2013 8:30 pm Post subject: |
The one I still have is the first of 4...there was a 307, a completely dismantled 305 (or 350; I can't remember) and the 305 that's in John's TA now. Gabe's 355 looked tempting, but I'm not ready to invest in a build...maybe one day.  _________________
Posted: Fri Mar 08, 2013 3:05 pm Post subject: |
| turbo_jimi wrote: | | chevymad wrote: | | Do you need a 4 bolt 350 rebuilder? |
Are you talking about another engine. Not really. I have one that's been sitting in my shop for over 3 years.  |
That one is actually mine.  |
turbo_jimi Member
Posted: Fri Mar 08, 2013 3:47 pm Post subject: |
Darn it! I thought you forgot it was yours.  _________________
Posted: Fri Mar 08, 2013 11:46 pm Post subject: |
| turbo_jimi wrote: | Darn it! I thought you forgot it was yours.  |
I guess who ever comes up with the money to rebuild it first can have it!  |
