Help Passing DEQ
Goto page 1, 2, 3  Next
G33K5QU4D
1983 Chevrolet Camaro
PostPosted: Wed Jun 04, 2014 6:06 pm    Post subject: Help Passing DEQ Reply with quote
Hey guys,
So my problem is that my 83 fails DEQ both times I've taken it in. The hydrocarbons or whatever are reading into the 3000's, when it says it can only be 220. Took it to a shop, said it was going to be $2000 to replace the catalytic converter, we were like nope, lowered the idle, and somehow it did way worse, reading in the 4000's. Anyone have any idea on how to fix this?
1983 Camaro
PostPosted: Wed Jun 04, 2014 6:27 pm    Post subject: Reply with quote
check your timing
make sure it has no faulty ignition parts
bad cat
check your compression
PostPosted: Wed Jun 04, 2014 6:47 pm    Post subject: Reply with quote
If you want to fix it a new Magnaflow cat is like $80, but you might want to figure out if something else took the cat out.
If you just want to pass you want a high idle, very retarded ignition timing, a very hot engine, and as much isopropyl as the thing will take without stalling.
PostPosted: Wed Jun 04, 2014 8:37 pm    Post subject: Reply with quote
$2,000.00 to replace a catalytic converter is insane. I hope that was a typo. I had this job done once and it was 200.
I have a catalytic converter from my 86 firebird that has about 50,000 miles on it. I would be willing to let it go cheap. Should be less than $100 to have it installed by an exhaust shop. Especially if we cut your old one off first.
You will need to figure out why the old one failed, or else the new one will too.
G33K5QU4D
PostPosted: Wed Jun 04, 2014 9:19 pm    Post subject: Reply with quote
They wanted to replace a bunch of other things as well, but I figured 2000 just to pass emissions was way too much. They said something about the carb leaking fuel, although I hadn't seen that happen. It feels and sounds like it's running fine, though.
1983 Camaro
PostPosted: Thu Jun 05, 2014 6:52 am    Post subject: Reply with quote
G33K5QU4D wrote:
carb leaking fuel
Please tell me you are not still running the Rochester sequential 2-barrel on there.
If so I think I may have figured out your problem. Laughing
G33K5QU4D
PostPosted: Thu Jun 05, 2014 7:22 am    Post subject: Reply with quote
I have the original carb in there, by the sound of it, those tend to fail? What should I get to replace it?
1983 Camaro
PostPosted: Thu Jun 05, 2014 8:19 am    Post subject: Reply with quote
MPFI Very Happy
I kid, I am out of my element here.
G33K5QU4D
PostPosted: Thu Jun 05, 2014 8:32 am    Post subject: Reply with quote
As ideal as that would be,I haven't the slightest clue as to how to convert, and it would probably be outside of my budget haha. I would be interested in picking up your cat, though, just to see if that makes a difference.
1983 Camaro
PostPosted: Thu Jun 05, 2014 10:36 am    Post subject: Reply with quote
I can cut it off this evening after work. if you want to swing by I have a garage full of parts right now, you might see something else you want/need. I have the most comfortable seats you will ever sit in, you have to give them a test sit.
G33K5QU4D
PostPosted: Thu Jun 05, 2014 10:53 am    Post subject: Reply with quote
That would be awesome, if you wanna pm me your address I can swing by later.
1983 Camaro
G33K5QU4D
PostPosted: Sun Jun 15, 2014 7:37 pm    Post subject: Reply with quote
UPDATE: Got the new cat on (Thanks for it btw), swapped out the carb, changed the oil, ect, my tester says it's looking pretty good, gonna take it to DEQ this week, hopefully it passes, as this will be my fourth attempt lol.
1983 Camaro
BluFbdy
PostPosted: Mon Jun 16, 2014 3:07 pm    Post subject: Reply with quote
If it fails, isopropyl alchohol would do the trip as mentioned before, always passed the sniffer in az with that, never had a core in my catalytic converter but the alchohol made up the difference
PostPosted: Mon Jun 16, 2014 9:20 pm    Post subject: Reply with quote
Right on. I still have those seats too Wink
G33K5QU4D
PostPosted: Sat Jun 21, 2014 9:34 pm    Post subject: Reply with quote
UPDATE AGAIN: shop said like 2 cylinders weren't firing at all, which I guess explains the high hydrocarbons. Not sure the cause of that problem yet, shop still working on it. Once that gets fixed, I'd be down to check out those seats again and that one bar if that's still available.
1983 Camaro
G33K5QU4D
PostPosted: Wed Jun 25, 2014 6:06 pm    Post subject: Reply with quote
OK, shop fixed ignition timing and all that jazz, but still has slightly too high hydrocarbons. The hydrocarbons go up when doing the throttle test for some reason. Also it has high CO2. I was gonna call the shop back up and say it didn't pass, but I am at a loss as to what is causing it to fail still. I took it twice today.
I might just give the alcohol thing a shot and see how that works.
1983 Camaro
PostPosted: Wed Jun 25, 2014 6:47 pm    Post subject: Reply with quote
If I remember correctly, oregon makes you pass a higher standard today then the car was originally designed for. Basically they want them off the road. Didn't Dewey try like 40x before passing? I'd load the thing with alcohol and give it a go.
PostPosted: Thu Jun 26, 2014 6:21 am    Post subject: Reply with quote
Use race grade methanol. About a 1:5 ratio. Or Drill a 5/16 hole 4-5" infront of your cat from the driver side.
PostPosted: Thu Jun 26, 2014 9:23 am    Post subject: Reply with quote
Could yo drill that hole in the blocked off air injection pipe paul? His can has a blocked off air injection hole.
G33K5QU4D
PostPosted: Thu Jun 26, 2014 10:41 am    Post subject: Reply with quote
Taking it back to the shop today. Failed a third time after I got it back.
1983 Camaro
Page 1 of 3
