Posted: Tue May 31, 2011 7:04 pm Post subject: Camaro idles like **** in hot weather |
Saying it idles at all is optimistic. More like shuts off every time I let off the throttle. What used to be a poor idle in cooler weather is now a serious problem in warmer weather.
Should I,
1. Pay the big bucks and have a professional shop tune and troubleshoot the car? $500 minimum assuming there is nothing wrong besides the tune but it will run perfect when it comes back.
2. Do mail order tune from Frost. $200 and won't fix a thing if it is related to something else on the car. Might not be optimal for me either.
3. Buy my own credits to tune the car for $100. I have HP Tuners (came with my new engine) but I have zero, let me repeat ZERO, experience tuning engines. |
IROCDave Member
Posted: Tue May 31, 2011 8:08 pm Post subject: |
You know what the right answer is.
Mail order tunes can work if your running a common combination, just wont be perfect. If your going to yank the drive train and put it your bird eventually, get a canned tune. Once it is in the bird spend the dough and have a local shop tune it.
JMO. |
Posted: Tue May 31, 2011 9:23 pm Post subject: |
Spend the $100 and dive into the world of tuning!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Tue May 31, 2011 9:46 pm Post subject: |
| RSFreak wrote: | Spend the $100 and dive into the world of tuning!  |
See tuning is just like engineering...
As long as you never drive the car, you did everything great!  |
Posted: Wed Jun 01, 2011 7:09 pm Post subject: |
| aaron_sK wrote: | | RSFreak wrote: | Spend the $100 and dive into the world of tuning!  |
I take offense to that. I just had a prototype coach assembled with custom proto harnesses that I designed that worked great on the first start. So there :p
And you are sure your sensors are good? Sounds like a bad intake air sensor or maf. _________________ E30
Posted: Thu Jun 02, 2011 3:16 pm Post subject: |
| blue89 wrote: | | I just had a prototype coach assembled with custom proto harnesses that I designed that worked great on the first start. So there :p |
What a nerd.
| blue89 wrote: | | And you are sure your sensors are good? Sounds like a bad intake air sensor or maf. |
Not entirely sure. There are no trouble codes related to that. I have been looking for a cheap used throttle body and MAF just to have on hand. |
Posted: Thu Jun 02, 2011 6:44 pm Post subject: |
I speak and live geek!
Just because you don't have a code doesn't mean there isn't a sensor spitting out the wrong info. |
Posted: Thu Jun 02, 2011 8:13 pm Post subject: |
| I know all the harness experts where I work. It's not an easy job. Most people don't realize how challenging it is to make a wire harness survive on a machine that can rip solid granite, works at -40C, and is high pressure washed routinely. |
Posted: Fri Jun 03, 2011 6:09 am Post subject: |
| I totally agree with you. This is my first experience with highway vehicles and it is an eye opener. Cavity plugs are your friend! And if you guys ever need help with identifying connectors, I'm that guy. Delphi, Packard, Tyco, FCI, Framatome, you name it. |
Posted: Fri Jun 03, 2011 8:16 am Post subject: |
| I hope you do better then the last motorhome I worked on. There must have been a sale on yellow wire. Every single bit of wire the coach company added was yellow. |
Posted: Fri Jun 03, 2011 7:00 pm Post subject: |
ARGGGHHH!!!
The HP Tuner suite I have is the older serial cable and it can't be upgraded for new vehicles. It only took me two nights of frustration to figure that out.
Back to square one.  |
IROCDave Member
Posted: Fri Jun 03, 2011 7:57 pm Post subject: |
When in doubt replace the MAF. If the ECM has been worked over do not realy on the trouble codes. Search this site as well as thirdgen.org for the issues that caused me trouble for several months.
Long story short MAF trouble codes can be limited or just ignored with programming. |
Posted: Sun Jun 05, 2011 8:27 pm Post subject: |
I am constantly reminded why I didn't become a mechanic for a living. I suck at it.
I forgot that my turbo engine came with an MAF sensor so I swapped it in. Problem is I dropped it by accident trying to push it into the SLP lid. In my panic to not let it hit the concrete floor I bobbled it in the air several times and caught it, but I put my fingers inside the sensor. I'm not sure if I touched the heater wires but they seemed to be secure.
Anyway, the car ran a whole lot different. The idle is better, the MIL light is off, the car is a lot quieter, it coasts longer when letting off the throttle as if it is being ever so slightly pushed, and the exhaust seems to cackle a lot when the engine is decelerating under no load. Bad part is the Service Engine Light is on now and there are no codes so I don't know why.
I have no idea what changes are good vs. bad. It really makes me nervous that the cars sounds so much different. I'm seriously thinking of buying HP Tuners so I can have the scanner feature. My handheld OBD2 scanner just isn't telling me much. I mean, there should be some information as to why the ECM turned on the SES light, right??? |
Posted: Sun Jun 05, 2011 8:38 pm Post subject: |
| Is it throwing the SEL after you've cleared codes with your scanner (or unhooked the battery)? |
Posted: Sun Jun 05, 2011 8:41 pm Post subject: |
There are no codes to clear. That's what is pissing me off. I unhooked the battery for at least 15 minutes and the SEL came on immediately upon start up.
It's also mid-90F here with humidity and that is pissing me off, too.
Posted: Sun Jun 05, 2011 8:43 pm Post subject: |
| Swap the old MAF back in real quick to test it. |
Posted: Sun Jun 05, 2011 8:45 pm Post subject: |
| That was my next planned move. It's too late here now because the car is so loud it will disturb the neighbors. |
Posted: Sun Jun 05, 2011 8:59 pm Post subject: |
| QwkTrip wrote: | | it coasts longer when letting off the throttle as if it is being ever so slightly pushed, and the exhaust seems to cackle a lot when the engine is decelerating under no load. |
These seem to indicate the ECU is not turning off the injectors under coast. TPS out of spec? Something is making it not think it's at 0% throttle. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Jun 05, 2011 10:38 pm Post subject: |
| Alphius wrote: | | QwkTrip wrote: | | it coasts longer when letting off the throttle as if it is being ever so slightly pushed, and the exhaust seems to cackle a lot when the engine is decelerating under no load. |
These seem to indicate the ECU is not turning off the injectors under coast. TPS out of spec? Something is making it not think it's at 0% throttle. |
That all depends on the tune. My buddy's goat cackled like mad on zero throttle decel after we threw headers/exhaust on it. Even after a decent tune it still does it to a certain extent. _________________
Posted: Mon Jun 06, 2011 7:07 am Post subject: |
| iansane wrote: | | Alphius wrote: | | QwkTrip wrote: | | it coasts longer when letting off the throttle as if it is being ever so slightly pushed, and the exhaust seems to cackle a lot when the engine is decelerating under no load. |
That all depends on the tune. My buddy's goat cackled like mad on zero throttle decel after we threw headers/exhaust on it. Even after a decent tune it still does it to a certain extent. |
True. But if it used to not, and now it does with no tuning changes that's a sure sign that fuel is now being let into the exhaust when before... it wasn't. _________________ 84 Camaro Z28 - LS1/T56
