emissions question
Wolffy
PostPosted: Sun May 01, 2011 9:39 am    Post subject: emissions question Reply with quote
i gotta deal with either getting emissions or "moving" to a location that doesnt have them
my question is since i dont have an EGR valve will it pass or fail based on that?
im running the HSR with 24lb injectors & a 58mm throttle body
all other emissions crap is still on
thanxs
PostPosted: Sun May 01, 2011 1:45 pm    Post subject: Reply with quote
In Oregon I know they don't check for NOx emissions, which is what the EGR is for. Dunno about Washington though, I was under the impression Washington isn't as strict on emissions.
PostPosted: Sun May 01, 2011 5:28 pm    Post subject: Reply with quote
WA doesn't check for NOx on the old cars.
Wolffy, where are you failing the test?
Wolffy
PostPosted: Sun May 01, 2011 9:39 pm    Post subject: Reply with quote
i havent gotten it tested yet
im asking so i dont fail & have to spend $$$$ to fix a non-existant problem
id rather just get it licensed elsewhere so i dont have to deal with this crap, but ....
PostPosted: Sun May 01, 2011 10:06 pm    Post subject: Reply with quote
Just run it in and check it once. Then fix anything that comes up. The first retest is free.
I've gotten a TON of crap past the sniffer in this state. Mostly just with Iso-Heat.
