		| Author | Message |
		| SlackerTA Member
				|  Posted: Mon Mar 14, 2011 6:08 pm    Post subject: Spring Rates |   |
				| I've been doing lots of research on spring rates and suspension setups for our cars and there's a few options so I want your guys opinions. I want something that's not too harsh but will compliment my soon to be installed 36/23mm sway bar combo.
 Lots of people really like factory ws6 springs or the moog equivalent for the front and the progressive rate "cargo" springs for the rear. Others swear by the Eibach Pro Kits. Any suggestions?
 '91 Firebird - LO3, 700R4, 2.73 gears
 '85 Trans Am - SOLD
 '95 Z28 - SOLD
		| Back to top |  |
		| blue89 Member
 1986  Chevrolet  Camaro RS
		| Back to top |  |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Mon Mar 14, 2011 6:16 pm    Post subject: |   |
				| I like the stock WS6 springs I bought from Brandon.  I cut 1/2 coil out of each.  The ride is a bit rough, but handles pretty good.  Shocks/struts also have a lot to do with ride handling, I have the Tokico Illumina adjustable, not as good as Koni, but I like them. _________________
		| Back to top |  |
		| blue89 Member
				|  Posted: Mon Mar 14, 2011 6:19 pm    Post subject: |   |
				| I agree with you al. Also don't forget weight. My 1550lb front end when I had the v6 was very rough with around 600lb in springs. |  |
		| Back to top |  |
		| SlackerTA Member
				|  Posted: Mon Mar 14, 2011 6:32 pm    Post subject: |   |
				| I also saw the Vogtland springs that are progressive front and rear. Their rates are 336-628lbs front and 183-228lbs rear. Not as high as WS6 springs but they seem like they would ride well and still handle nicely. The few people I can find that have used them seem to like them. |  |
		| Back to top |  |
		| blue89 Member
				|  Posted: Mon Mar 14, 2011 9:22 pm    Post subject: |   |
				| I like my rear progressives. They would be a better compromise if thats what you are going for. You need to get the height you want cause you don't want to trim a progressive much. |  |
		| Back to top |  |
		| SlackerTA Member
				|  Posted: Mon Mar 14, 2011 10:59 pm    Post subject: |   |
				| It seems that, price wise, the Moog replacements in WS6 rates are the way to go. I've also read that, like Al, cutting 1/2 a coil off gives just the right amount of lowering. _________________
 '85 Trans Am - SOLD
 '95 Z28 - SOLD
		| Back to top |  |
		| Quasi-Traction "I have petals"
				|  Posted: Tue Mar 15, 2011 4:31 pm    Post subject: |   |
				|  	  | SlackerTA wrote: |  	  | I've also read that, like Al, cutting 1/2 a coil off gives just the right amount of lowering. |
 You'll have to drive it around for a while and see where the springs settle at. I started out only taking a 1/4 off at a time, both Front and rear. Fronts are down 1/2 coil (and I still think it should go another 1/4 coil), and rear's are down about 3/4" coil. You can go a bit lower that most other people since you have no GFX, so your only big concerns will be the front X-member and possibly your exhaust and air dam.
 I'm still strongly considering the "Ground control" kit like DBL_TKE (Skyler) and Dewey have, if I go lower.
		| Back to top |  |
				|  Posted: Tue Mar 15, 2011 5:50 pm    Post subject: |   |
				| I've got 3/4 cut off the front of my stock Iroc springs, and something like a coil and 1/4 in the back. I don't think mines harsh at all. Good shocks are a must.
 Always cut a little, with a cut off wheel (no torch), and then install and drive for TWO WEEKS to allow the springs to settle. Do this before deciding it's not low enough, etc.
		| Back to top |  |
		| SlackerTA Member
				|  Posted: Tue Mar 15, 2011 8:10 pm    Post subject: |   |
				| Alright, good info guys. Thanks! I'm collecting the suspension parts I want and then I'll install them all at once. I just need springs/dampers and some SFCs and I'm ready to get to work. |  |
		| Back to top |  |
		| RSFreak The other "John"
 1989  Chevrolet  Camaro RS
				|  Posted: Tue Mar 15, 2011 8:42 pm    Post subject: |   |
				|  	  | Twilightoptics wrote: |  	  | I've got 3/4 cut off the front of my stock Iroc springs, and something like a coil and 1/4 in the back. |
 Are the IROC springs the same rates as WS6?
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Tue Mar 15, 2011 8:49 pm    Post subject: |   |
				| Irocs are stiffer then WS6. Chevy thought stiff springs and soft sway bars were the way to go.. Pontiac thought opposite. |  |
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Fri Mar 18, 2011 1:23 am    Post subject: |   |
				| For reference...I run something like 875/225 with 36/24 bars.  It is all a matter at preference at some point, and how stiff of a ride you want.  I think the pro-kit spring rates are pretty good for a off the shelf kit.  I like their rates better than the sportlines.
 As Paul said.  Good shocks are a must with the stiffer springs.
		| Back to top |  |
		| blue89 Member
				|  Posted: Fri Mar 18, 2011 7:46 am    Post subject: |   |
				| Don't forget lca relocater brackets for the rear.
 I have iroc springs with 2 coils missing and 125/175 rear 4th gen progressive.
		| Back to top |  |
		| 91RSVert Member
 1991  Chevrolet  Camaro RS
				|  Posted: Fri Mar 18, 2011 10:40 am    Post subject: |   |
				| Whatever jamex spring rates are here.
 Still dont have lca relocation brackets
		| Back to top |  |
		| DBL_TKE Member
 1991  Chevrolet  Camaro Z/28
				|  Posted: Sat Mar 19, 2011 5:02 pm    Post subject: |   |
				| I'm running 800/200 and 36/21 sway bars on my Z28. Not harsh by any means. It handled pretty damn well with some KYB adjustable shocks and struts. There were a couple of times where I wished I had gone stiffer but that was only on the race track. _________________
		| Back to top |  |
