Cascade Crew Message Forums
vega_guy_76 Member
Joined: 02 Jan 2005 Posts: 79 Location: St Helens, OR
Posted: Thu Mar 31, 2005 9:59 pm Post subject: Dyno or bust; Maybe bust on the dyno |
Yesterday I decided it would be a good time to pull the oil pan off my Sprint to fix the leaky gasket. Even though it was raining everything went as planned, until I got the pan off and looked inside. Click here and take a peek at the last two pics. The very last pic shows a chunk of a timing chain gear and two pieces of roll-pins that were used for the distributor gear. Other things I looked at was three flattened cam lobes. I'll still be planning on running it on the dyno. If it let's loose, oh well. I can get another motor for it real cheap.
Charlie _________________ 2000 Dodge Dakota SLT Club Cab 4x4, 3.9 V6, 5spd manual, 3.55 gears
1976 GMC Sprint SP, Buick 455, TH400, 2.56 gears--- 14.640 @ 93.22mph 2.234 60'
1976 Vega Wagon, Buick 3.2L V6, TH350, 2.56 gears |
Posted: Fri Apr 01, 2005 7:45 am Post subject: |
That sucks.
I think I'll just stand somewhere else when you run.  |
Posted: Fri Apr 01, 2005 10:56 am Post subject: |
