		| Author | Message |
		| blue89 Member
 1986  Chevrolet  Camaro RS
				|  Posted: Tue Mar 08, 2011 3:15 pm    Post subject: brake kit bolts |   |
				| When you guys did your front brake kits, did you use lock tight for the caliper relocation brackets and wheel spacers? I figured it would be good to do since I never intend to take them off again. _________________
		| Back to top |  |
				|  Posted: Tue Mar 08, 2011 4:11 pm    Post subject: |   |
				| The caliper carrier mounting bracket yes. After test fitting the complete setup.
 Wheel spacers?
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Tue Mar 08, 2011 4:27 pm    Post subject: |   |
				| Even with loctite I've had mine shimmy loose. Next time the front end is in the air they're getting safety-wired. _________________
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Tue Mar 08, 2011 4:40 pm    Post subject: |   |
				| YES on the brake adapters.  I had one shimmy loose also, I used red when I did them last time, so far so good.  Ian's idea of safety wiring them is a good one, if you have a line of sight and bolt heads that will work for it.  The layout of my -V calipers won't allow for me to safety wire the adapter bolts.  I have lock washers, and lock-tite to hold them in.
 Wheel adapters, I didn't use any one.  Make sure you follow the torque procedure you get, and recheck the torque several times in the first few hundred miles.  I have not had any problems with them after initially getting the bolt stretch and the alum stretch out of the way.
		| Back to top |  |
				|  Posted: Tue Mar 08, 2011 5:58 pm    Post subject: |   |
				| I think safety wire is overkill. Plus the PITA of drilling the holes in the bolt heads.
 Never had a problem with loc-tite and torqing the bolt to it's desired torque.
		| Back to top |  |
		| iansane Member
				|  Posted: Tue Mar 08, 2011 9:31 pm    Post subject: |   |
				| I love overkill.  |  |
		| Back to top |  |
		| blue89 Member
				|  Posted: Wed Mar 09, 2011 8:06 am    Post subject: |   |
				| Thanks guys. And ya, using spaces for the wagon wheels. I torqued the bolts down and used blue lock tite on the adapter bracket. I got everything up last night but was under the impression my 3rd gen brake lines would work. Brake lines are too small at the caliper. Now what? Do I get 98+ lines? |  |
		| Back to top |  |
		| blue89 Member
				|  Posted: Thu Mar 10, 2011 9:25 am    Post subject: |   |
				| Ended up the ls1 caliper has larger bolt heads, a larger bolt shaft, different thread, but still fit the brake lines. Crisis averted and parts installed! |  |
		| Back to top |  |
