brake kit bolts
PostPosted: Tue Mar 08, 2011 3:15 pm    Post subject: brake kit bolts Reply with quote
When you guys did your front brake kits, did you use lock tight for the caliper relocation brackets and wheel spacers? I figured it would be good to do since I never intend to take them off again.
PostPosted: Tue Mar 08, 2011 4:11 pm    Post subject: Reply with quote
The caliper carrier mounting bracket yes. After test fitting the complete setup.
Wheel spacers?
PostPosted: Tue Mar 08, 2011 4:27 pm    Post subject: Reply with quote
Even with loctite I've had mine shimmy loose. Next time the front end is in the air they're getting safety-wired.
PostPosted: Tue Mar 08, 2011 4:40 pm    Post subject: Reply with quote
YES on the brake adapters. I had one shimmy loose also, I used red when I did them last time, so far so good. Ian's idea of safety wiring them is a good one, if you have a line of sight and bolt heads that will work for it. The layout of my -V calipers won't allow for me to safety wire the adapter bolts. I have lock washers, and lock-tite to hold them in.
Wheel adapters, I didn't use any one. Make sure you follow the torque procedure you get, and recheck the torque several times in the first few hundred miles. I have not had any problems with them after initially getting the bolt stretch and the alum stretch out of the way.
PostPosted: Tue Mar 08, 2011 5:58 pm    Post subject: Reply with quote
I think safety wire is overkill. Plus the PITA of drilling the holes in the bolt heads.
Never had a problem with loc-tite and torqing the bolt to it's desired torque.
PostPosted: Tue Mar 08, 2011 9:31 pm    Post subject: Reply with quote
I love overkill. Very Happy
PostPosted: Wed Mar 09, 2011 8:06 am    Post subject: Reply with quote
Thanks guys. And ya, using spaces for the wagon wheels. I torqued the bolts down and used blue lock tite on the adapter bracket. I got everything up last night but was under the impression my 3rd gen brake lines would work. Brake lines are too small at the caliper. Now what? Do I get 98+ lines?
PostPosted: Thu Mar 10, 2011 9:25 am    Post subject: Reply with quote
Ended up the ls1 caliper has larger bolt heads, a larger bolt shaft, different thread, but still fit the brake lines. Crisis averted and parts installed!
