kurfbird Member
Posted: Fri Mar 11, 2005 2:00 pm Post subject: Defrost switch |
I have a firebird 1989 2.6 700 R4 that did not come with a rear defroster. I got a switch and wiring but when I hooked up the switch there is no voltage coming out of the connector. ALso when I push the switch It does not lock into position. and the light does not come on.
Can some on help me out and let me know how there works on there Firebird.
If you have a spare working switch let me know. Maybe we can work something out.
Thanks
Kurbird _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
PonchoTA Member
Posted: Fri Mar 11, 2005 3:24 pm Post subject: |
Make sure power is getting to the connector. Usually if an option is not installed, the FUSE is not installed, but all the wiring may be there.
I'd check there first before giving up on the switch.
hth _________________ Paully |
kurfbird Member
Posted: Fri Mar 11, 2005 8:29 pm Post subject: defrost switch wiring |
I ve tried to trouble shooting the defrost switch but when I push the button the switch does not lock.
Does any of your switch lock even when there is no power.
I have even try to bench test the switch to the battery. Still no voltage going to the defroster.
If I take the power wire and jump it to the defrost wire I get power.
Hook up power to the switch many different ways to the batteery but still no power will come out of the switch.
Give me some help here.
Kurfbird _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
JohnnyIROC-Z Member
Joined: 14 Jan 2004 Posts: 204 Location: Washougal, WA
1995 Pontiac Formula
Posted: Sat Mar 12, 2005 8:26 pm Post subject: |
| The switch doesn't lock, when you push it down the little amber light should come on. |
kurfbird Member
Posted: Sat Mar 12, 2005 8:30 pm Post subject: |
It doesn't
Tried to direct wire to the battery and it still would not work. I need a new switch. It might be that the switch that I got from J/Y was from a 86
kurfbird _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
JohnnyIROC-Z Member
Posted: Sat Mar 12, 2005 9:42 pm Post subject: |
| naw that wouldn't make a difference, but it's possible you have a bad switch ? |
kurfbird Member
Posted: Sat Mar 12, 2005 11:08 pm Post subject: defroster |
Yea the switch is bad now. I also found a conector on passinger side that comes from the switch. Will go to the J/Y monday and get the relay and switch.
I hope that this does it.
1991 Camaro 3.1 v6
700r4 Transmissions
JohnnyIROC-Z Member
Posted: Sun Mar 13, 2005 9:44 am Post subject: |
| Good luck man, If you run into trouble finding one or something let me know and I'll go and hunt one at the yards. shouldn't be THAT hard. |
kidcamaro Member
Joined: 09 Jan 2004 Posts: 325 Location: eugene/springfield
Posted: Sun Mar 13, 2005 10:58 am Post subject: |
| you might be able to use a momentary toogle switch instead. i had to use one before. it didnt light up but it worked. |
kurfbird Member
Posted: Wed Mar 16, 2005 1:11 pm Post subject: Defrost switch |
Finally got it working. Replaced switch. Then it staarted to work.
Now I need a Rear Hatch with defrost that will fit a 1989.
Thanks for all the help. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
