Posted: Wed Sep 22, 2010 7:14 pm Post subject: Difference between 4thgen and 3rdgen front spindles? |
I wanna upgrade my front brakes and I've seen a cool buildup in a car mag on a 4thgen and was wondering how hard it would be to duplicate on a 3rdgen.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Sep 22, 2010 7:20 pm Post subject: |
vs
4thgens have bolt-on hub/bearing and an upper control arm where as thirdgens have no upper control arm (spindle bolts directly to strut) and serviceable inner and outer bearing setup. _________________
Posted: Wed Sep 22, 2010 7:27 pm Post subject: |
| That being said, any brake upgrade you can do to a 4thgen, you can do to a thirdgen. |
Posted: Wed Sep 22, 2010 7:36 pm Post subject: |
Basically, I just needed to know if the caliper bolts on the same way and are the dimensions the same? Would it be possible to put a 4thgen caliper on a 3rdgen spindle? How about rotors from a C5/C6? I figured you'd be the one to know Ian.  |
Posted: Wed Sep 22, 2010 7:38 pm Post subject: |
Most brake upgrades require removing the dust shield and drill/tapping the shield holes for a caliper carrier bracket. _________________ A redline a day keeps the carbon away! |
Whiskeychick Member
Joined: 19 Sep 2010 Posts: 225 Location: Penticton BC
1987 Pontiac GTA
Posted: Wed Sep 22, 2010 7:40 pm Post subject: |
Its actually not really that much work if you swap a full 4th gen setup in.
I know if you dig on thirdgen you can find a pretty good how too. I looked into it when I did the rear LS1 swap.
I believe there was a simple mod (removing a small piece) that you had to do to the 4th gen spindle to make it work in a 3rd gen. But I was reading this last year lol, so its a little foggy now.
Also, check LS1tech, and LT1LS1 for cheap parts. When they parts out cars you can usually get everything you need dirt cheap.
I paid 200 bucks for a full rear end brake swap, backing plates out, including all brackets, ebrake cables etc. _________________ 1987 - Trans am GTA, hooker headers, Borla catback, Cat delete, CAI, 9.6 @ 75mph 1/8mile
2008 - Mini Cooper Clubman S, Hot Chocolate on Hot Chocolate Lounge Leather  |
Posted: Wed Sep 22, 2010 7:45 pm Post subject: |
| John, you gotta be making some sort of power before you need to worry about brakes. |
Posted: Wed Sep 22, 2010 8:59 pm Post subject: |
| RSFreak wrote: | Basically, I just needed to know if the caliper bolts on the same way and are the dimensions the same? Would it be possible to put a 4thgen caliper on a 3rdgen spindle? How about rotors from a C5/C6? I figured you'd be the one to know Ian.  |
No, they don't bolt on the same. As Paul said you'd need to drill/tap the dust shield holes for something larger (usually 3/8,10 or 12mm) and bolt on an adapter bracket. Then you can just bolt on a 4thgen, c4,c5,c6, ctsv, zr1 etc caliper/abutment bracket or whatever you want.
| aaron_sK wrote: | | John, you gotta be making some sort of power before you need to worry about brakes. |
When I first swapped the c6s on I was 225hp and 14" 6pots.
Grab a spare set of spindles from the JY and start hacking.
Here, use this;
Posted: Wed Sep 22, 2010 9:27 pm Post subject: |
| iansane wrote: | Here, use this;
After making the cut on the dotted line above, your spindles should look something like this...
Adapter brackets added after drill & tap of the dust shield bolt holes, the ones you get may look slightly different, but they bolt up the same...
They install on the car like so...
Then the hub and rotor go on prior to installing the caliper bracket...
I'd be glad to help when you get this started. I also have a set of unmolested spindles I could let go cheap  _________________ 92 Camaro
Posted: Wed Sep 22, 2010 9:29 pm Post subject: |
Those calipers look familiar...  |
Posted: Wed Sep 22, 2010 10:11 pm Post subject: |
| Al, what size are those rotors and what are they from? Also, where did you get the adapter brackets? |
Posted: Wed Sep 22, 2010 10:14 pm Post subject: |
| iansane wrote: |
With the same motor I have now BTW.
Ian, what wheels did you have with those 14" rotors? Will my Z06s clear that size? |
Posted: Wed Sep 22, 2010 10:20 pm Post subject: |
| RSFreak wrote: | | Al, what size are those rotors and what are they from? Also, where did you get the adapter brackets? |
Those are Ian's old C5 brakes. The rotors are 12.75" - the brackets came from this site...
http://www.kore3.com/proddetail.php?prod=10088-01 _________________ 92 Camaro
Posted: Wed Sep 22, 2010 10:36 pm Post subject: |
| RSFreak wrote: | | Ian, what wheels did you have with those 14" rotors? Will my Z06s clear that size? |
I ran the 18" c5 wagon wheels and then my current 18" c6 wheels.
Your zo6s won't clear c6 Z stuff but they will clear the c6 Z51 setup. 13.4" rotor and the same caliper Al is running (well, a slightly updated designed to reduce caliper spread when tracked). |
Posted: Wed Sep 22, 2010 10:59 pm Post subject: |
| What rotors are you running Ian? What size are your C6 rims? |
Posted: Thu Sep 23, 2010 9:55 am Post subject: |
Rotors are from an '08 Z06. Just bought new wagner replacements for $40/pc  |
Posted: Thu Sep 23, 2010 9:58 am Post subject: |
I know who I'm coming to for parts!  |
Posted: Thu Sep 23, 2010 8:07 pm Post subject: |
Hey Ian, you have mail!  |
Posted: Thu Sep 23, 2010 8:45 pm Post subject: |
Replied. _________________
Posted: Sat Sep 25, 2010 7:09 pm Post subject: |
gotta love our employee discount huh.
what size brakes do you think we could fit under my 14in wheels? do you think a stock 2 piston 4th gen caliper would fit? probably... not lol
