350 upgrade ?
86toy
1986 Pontiac Trans Am
PostPosted: Sun May 02, 2010 9:05 am    Post subject: 350 upgrade ? Reply with quote
Hey guys, im thinking about getting a 350 shortblock for my 86 t/a. i was wondering, how well the 305 heads will work on the 350? motor will be basicaly stock maybe a mild cam.
thanks shad. Razz
86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
245/45/17 restoring
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sun May 02, 2010 10:46 am    Post subject: Reply with quote
Need more information on the motor and specific heads. Deck Height, Bore, Chamber size, piston CC etc.
PostPosted: Sun May 02, 2010 11:03 am    Post subject: Reply with quote
If you have factory dished pistons it would probably be an ok match. Flat tops you'll probably have too much compression without some work to the heads.
IROCDave
PostPosted: Fri May 28, 2010 5:06 pm    Post subject: Reply with quote
I would not install 305 heads on any 350. My wifes car has this settup, it makes good tourqe until 3K then falls on it's face. Spend another 500.00 and pick up a decent set of 350 heads. It will be money well spent.
PostPosted: Fri May 28, 2010 5:26 pm    Post subject: Reply with quote
Really depends on the heads and cam and heads that WERE on there.
Seen lots of 70's low compression smog motors wake up with a 305 head.
IROCDave
PostPosted: Fri May 28, 2010 6:01 pm    Post subject: Reply with quote
The minor bump in compression is not worth the loss of flow that the tiny 305 valves provide. Spend the dough and at a minimum, use a set of L98 cast iron heads. Keep in mind you can pick up a set of superior alluminum after market heads that flow well for 500.00 or less. See my post regarding trading a used set of TrickFlows for a SR. No need to cheap out on a decent set of heads nowadays.
