v8 auto transmission
PostPosted: Mon May 10, 2010 11:48 am    Post subject: v8 auto transmission Reply with quote
My transmission is going out and I will need another one for a couplee months.
I have a manual trans to go in, but I do not have time to do that swap right now.
So does anyone have a CHEAP auto transmission that will last me a couple months??[/quote]
-Donald
PostPosted: Mon May 10, 2010 11:52 am    Post subject: Reply with quote
C'mon if you have everything it doesn't take much more time to swap the T5 in than it does to R&R an automatic.
There are enough of us guys that might be willing to work for Beer/Pizza in the Tacompton/Seattle area that I'm sure we could get you rowing in no time. Especially if you have access to an air compressor.
PostPosted: Mon May 10, 2010 2:36 pm    Post subject: Reply with quote
^ This. ^
We'll be busy on the 22nd, and we need to change John's clutch at some point, but buy the swap stuff, and throw a weekend out there Donald. I'll show up with my topbox. Yup yup
PostPosted: Mon May 10, 2010 4:44 pm    Post subject: Reply with quote
I have been looking for the parts!
But all I have is the transmission
Any good place to look for those parts??
I am driving in d2 because there is no third gear in d or od
How long can I drive in d2??
-Donald
PostPosted: Mon May 10, 2010 6:33 pm    Post subject: Reply with quote
Clutch material in the fluid means I'd imagine you wont be driving around in second for long. When the 700 in the IROC blew the fluid went from bright red to dark grayish-brown immediately. Plus the top speed of like 40 kinda sucks. Razz
Try the Pull-A-Part by McChord. They rarely have a decent turdgen there, but if they do it's like less than $100 for everything including a transmission. Get down and Boogie!
If not, try the one in Tumwater.
kurfbird
PostPosted: Mon May 10, 2010 8:58 pm    Post subject: 700r4 Reply with quote
A pick up trasnmission will work also. Same trans as long as they are the same length.
I will have a 700r4 in a few weeks going to replaced my wifes one with a new one.
Also have a slave cylidner and and set of pedals.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Mon May 10, 2010 10:34 pm    Post subject: Re: 700r4 Reply with quote
With the clutch pedals??
How much you want??
-Donald
86toy
1986 Pontiac Trans Am
PostPosted: Wed May 12, 2010 6:11 pm    Post subject: Reply with quote
i heard all auto wrecking on mountain highway has a few third gens out there, the ones at pull apart are v6 cars.
86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
245/45/17 restoring
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed May 12, 2010 6:20 pm    Post subject: Reply with quote
They'll be out there awhile longer if their prices don't come down.
kurfbird
PostPosted: Wed May 12, 2010 7:12 pm    Post subject: V6 700r4 Reply with quote
I have a low mileage 700 r4 v6 only 96,000 from a 87 firebird. Wiith torque converter. 100.00
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
91camaro_rs
PostPosted: Wed May 12, 2010 10:08 pm    Post subject: Re: V6 700r4 Reply with quote
he needs a V8 tranny...
kurfbird
PostPosted: Wed May 12, 2010 11:57 pm    Post subject: Oops Reply with quote
Oops I looked at the info on his car
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
91camaro_rs
PostPosted: Thu May 13, 2010 12:20 am    Post subject: Reply with quote
his 87 has a v8 and 89 has V6
PostPosted: Thu May 13, 2010 10:55 am    Post subject: Re: V6 700r4 Reply with quote
From a v6? That's not the same as a v8 transmission is it??
-Donald
kurfbird
PostPosted: Thu May 13, 2010 12:04 pm    Post subject: V6 trnamission Reply with quote
No there are different.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Tue Jun 15, 2010 1:00 pm    Post subject: Reply with quote
I have an '85 700r4 from my camaro for $150 if you want it.
PostPosted: Tue Jun 15, 2010 1:33 pm    Post subject: Reply with quote
I've got a clutch reservoir with bracket for $15 and the ride there.
PostPosted: Wed Jun 16, 2010 11:57 am    Post subject: Reply with quote
replacement is already in.
-Donald
