Question about 4.3 v-6 fuel injectors
kidcamaro
PostPosted: Mon Mar 15, 2010 3:13 pm    Post subject: Question about 4.3 v-6 fuel injectors Reply with quote
To start off..this is in a chevy s10, on the way to work the truck died on me the other day and i have it narrowed down to the throttle body somewhere. When i turn the key to start it the engine cranks but wont start, im gettin fuel all the way to the injectors. When i pull the fuel pressure/regulator thing off the top theres fuel in the injector bowls, im not real good at trouble shooting electrical stuff but when the key is on i have power going to both injectors.
Im not sure if the problem is the injectors or a problem somewhere after the injector that is causing it to not spray fuel. Been workin on it for a few days now and im stumped now. Im not real knowledgable with fuel injection but i would think that with fuel in the injector bowl and it not pumpin fuel into the intake that it would be bad injectors. Its not pumpin fuel out of either injectors so possibly both are bad. Any help would be appreciated. Thanks in advance.
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger
PostPosted: Mon Mar 15, 2010 5:56 pm    Post subject: Reply with quote
What year?
kidcamaro
PostPosted: Mon Mar 15, 2010 5:57 pm    Post subject: Reply with quote
doh...sorry forgot to mention..my brain has been rattled tryin to get this fixed since sat...91 with a 4.3 v-6
kidcamaro
PostPosted: Tue Mar 16, 2010 10:49 am    Post subject: Reply with quote
well put some new injectors in today and still nothing...thinkin its probably electrical now.
PostPosted: Tue Mar 16, 2010 10:54 am    Post subject: Reply with quote
Injector driver, bad ground, bad wiring harness. Both injectors won't suddenly fail like that.
PostPosted: Tue Mar 16, 2010 10:57 am    Post subject: Reply with quote
distro pick-up? It is what tells the computer to fire the injectors. Just another thing to check.
kidcamaro
PostPosted: Tue Mar 16, 2010 11:17 am    Post subject: Reply with quote
i totally forgot to check the distro because when i dump fuel in the intake it will run till it burns off but i just pulled it off and its corroded in there so im cleanin it off and then gonna check again...thanks for the hints.
PostPosted: Tue Mar 16, 2010 11:29 am    Post subject: Reply with quote
You need to check the pick-up coil. not just the distributor cap. The pick-up coil tells the fire the injectors.
kidcamaro
PostPosted: Tue Mar 16, 2010 11:38 am    Post subject: Reply with quote
the book i have isnt very good at explaining how to test it. im not sure which wires to use to test as there are 3 sets of wires.
kidcamaro
PostPosted: Tue Mar 16, 2010 3:30 pm    Post subject: Reply with quote
well not sure exactly what was wrong but i just ended up changin out the whole distro since all the other parts i was gonna check would have come out to a little less so figured do it all in one shot....it fired right up. thanks for the advice and help guys. i really appreciate it.
PostPosted: Tue Mar 16, 2010 3:38 pm    Post subject: Reply with quote
Doh!
kidcamaro
PostPosted: Tue Mar 16, 2010 3:43 pm    Post subject: Reply with quote
yeah i shoulda learned from when my camaro did this to me before...changed and checked a bunch of stuff and when i changed out the distributor it fired right up...but least i know i got new gaskets and new injectors so wont have to worry bout those for awhile Very Happy
izcain
9sec Club
PostPosted: Wed Mar 17, 2010 5:39 pm    Post subject: Reply with quote
I would purchase a noid light kit if I was you. That would have saved you a whole lot of time.
9.17 @ 148
kidcamaro
PostPosted: Thu Mar 18, 2010 5:48 am    Post subject: Reply with quote
a what lol ?
izcain
9sec Club
PostPosted: Thu Mar 18, 2010 9:03 pm    Post subject: Reply with quote
It's a series of small testers that have very small bulbs in them. Each one fits a different type of injector connector. As you turn over the engine it will blink the bulb telling you that it has injector pulse.
9.17 @ 148
kidcamaro
PostPosted: Sat Mar 20, 2010 4:05 pm    Post subject: Reply with quote
yeah that woulda saved me time and money...ah well least i got new injectors and it does seem to be runnin lots smoother then before.
