timing
Goto page Previous  1, 2, 3  Next
Xecris
PostPosted: Sat Oct 31, 2009 1:37 pm    Post subject: Reply with quote
Sounds like the trans isn't locking up, would make a 200'ish rpm difference if it isn't. When I had another transmission put in my car, the lockup wasn't working. Easy test is to hit the highway, at light throttle, and tap the brake pedal just enough to light up the taillights. You should see the rpms jump up a couple hundred rpm.
My understanding with the 700r4, is that you aren't getting the cooling capacity if you aren't locking up, something like only 60% of your fluid gets through your cooling system if you aren't, and when it locks up, it will allow fluid to get from your torque converter through your cooling system. Could be hearsay, just what I got from the trans shop. Assuming it is a lockup converter, that is.
1991 Camaro RS - 454 BBC
PostPosted: Sat Oct 31, 2009 1:51 pm    Post subject: Reply with quote
From the LT1 swap thread:
chevymad wrote:
Without lockup 60% of the oil bypasses the trans cooler. Some screwed up thing gm did on their OD transmissions. Only when the convertor is locked does all the oil go through the cooler. So not only are you creating more heat because the convertor is unlocked, you have less of a chance to get rid of it.
Your tranny shop is correct.
91camaro_rs
PostPosted: Tue Nov 03, 2009 9:32 pm    Post subject: Reply with quote
ok so i tested this today, and the rpm's did go up when i pressed the brake, does the mean my lock up is or isnt working?
PostPosted: Tue Nov 03, 2009 9:39 pm    Post subject: Reply with quote
No, that's a good thing. You should also be able to feel it unlock when you give it part throttle when cruising in OD.
Basically you swapped out your stock 25" RS tires for 17" chrome IROC's, correct? Depending on your exact aspect ratio, you gained around one inch diameter. That will lower the RPM at cruise.
91camaro_rs
PostPosted: Tue Nov 03, 2009 11:55 pm    Post subject: Reply with quote
i had 15x7 (215/65/15) and i put on 17x8 (245/45/17), but now that the weather is getting crappy i put the 15's back on
next time im on the freeway ill try the overdrive unlock thing
PostPosted: Wed Nov 04, 2009 12:35 am    Post subject: Reply with quote
Your 215's are 25x8.5, your 245's are 26x9.6. That's your difference. Get down and Boogie!
Now that you got that settled, start thinking about something to make it faster. I, for instance, have been thinking a lot lately about how GM 3800II engines use the same 60* Metric bellhousing as the 2.8/3.1 engines... Squint
PostPosted: Wed Nov 04, 2009 5:19 am    Post subject: Reply with quote
I think I'm missing something here. Changing tire size will make the speedometer incorrect as well. Speed and RPM will have the same relationship regardless of tire size, until the speedometer gear is changed. Same was true when I removed the 3.08 rear end I had and swapped in a 3.23.
PostPosted: Wed Nov 04, 2009 9:16 am    Post subject: Reply with quote
Somewhere around here is a pic of Dewey's stock tach on the dyno as his LO3 spins to 8,000+ rpm.
His tach is prolly not 100% accurate.
But this thread gets a big LOL from me!! Laughing
PostPosted: Wed Nov 04, 2009 9:17 am    Post subject: Reply with quote
my tach says I idle at 3k rpms Laughing
PostPosted: Wed Nov 04, 2009 9:20 am    Post subject: Reply with quote
Correct, but the intake points to the rear making it hard to put in a rwd application.
What you should look at more is how the northstar motor uses the same 2.8/3.1 bellhousing Wink Ive seen one in a gen4 camaro.
91camaro_rs
PostPosted: Wed Nov 04, 2009 10:31 am    Post subject: Reply with quote
mine used to do that too, but i wired in the correct resistance to fix it,
i didnt know the 3800 motor had the same belhousing pattern, thats sweet, i should find one and swap em. haha northstar swap would be kinda cool.
i also have a stage 1 chip in it, idk if that will affect rpm's or anything
PostPosted: Wed Nov 04, 2009 11:02 am    Post subject: Reply with quote
Unless you have a 98+ V6 F body.
aaron, I can tell you for a fact that while the bellhousing flange is a 60 degree V6 pattern, the transmisssion mounts totally different. Also, I don't think you could use a 60 degree V6's bellhousing on a Series II 3800, because the starter mounts on the opposite side of the 2.8/3.1/3.4's, but I'm not 100% sure on that.
Boostd1
PostPosted: Wed Nov 04, 2009 11:25 am    Post subject: Reply with quote
3800's starters are on Bank 1 of the engine
2008 Saturn Astra XR | Sold
PostPosted: Wed Nov 04, 2009 1:05 pm    Post subject: Reply with quote
Ive never seen anyone try it on a gen4. Just gen3 and s10's
I have seen an L67 in a 55 chevy.
PostPosted: Wed Nov 04, 2009 4:39 pm    Post subject: Reply with quote
One of the regular customers that comes in to my work has a ferrari kit car built on a fiero chassis with an L67. Sounds just like a GTP, and he fools actual ferrari owners all the time at cars shows, he claims that they instantly stop talking to him and walk away when they find out its a replica. lol
'88 FORMULA
PostPosted: Wed Nov 04, 2009 5:30 pm    Post subject: Reply with quote
fiero l67 is quite commen.
A friend here deals in the kit replicas. He wont touch one with an aftermarket motor. I tried to talk him into one with a northstar.
PostPosted: Wed Nov 04, 2009 5:32 pm    Post subject: Reply with quote
for what its worth, my starter's on the driver side.
PostPosted: Wed Nov 04, 2009 5:33 pm    Post subject: Reply with quote
Same as a GTP... its on the "front".
Boostd1
PostPosted: Wed Nov 04, 2009 6:09 pm    Post subject: Reply with quote
Haha I'd love to see that thing!
PostPosted: Wed Nov 04, 2009 7:28 pm    Post subject: Reply with quote
You are correct that on the L36 and L67 engines, the starter is on the drivers side (front if thinking in terms of wrong-wheel-drive).
HOWEVER, I want you all to take a long hard look at this picture of a bellhousing from some 2.8/3.1 third-gen. Take a good long look at it.
Yeah... Twisted Evil
Page 2 of 3
