Outlaw28 Member
Posted: Fri Oct 23, 2009 3:06 pm Post subject: |
That is hot!
Outlaw28 Member
Posted: Fri Oct 23, 2009 3:40 pm Post subject: |
| yeah i thought ya'd like that... |
Posted: Fri Oct 23, 2009 4:42 pm Post subject: |
Looks like the ASC trans am that was revealed a few months ago.
Outlaw28 Member
Posted: Fri Oct 23, 2009 5:19 pm Post subject: |
| it does look similar but i c differences...like side intake the the LTA on the front fenders and a few other differences...still sweet looking ride i think i likem more then the new camaro |
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Fri Oct 23, 2009 5:48 pm Post subject: |
| It's to bad GM wacked Pontiac. I have always loved the looks of the early second gen Camaros and Firebirds. Hopefully GM can resurect Pontiac in a couple of years, G8 GT, G8 GXP ( should have been called "SD" ) Solstice GXP (again, should have been called "SD") Firebird, and performance varients. |
Posted: Fri Oct 23, 2009 6:17 pm Post subject: |
| The only pontiac I want to see is a G8 Bathurst edition. The Vaux VXR8 and Holden version that go the bathurst treatment are truely bad-arse. I would love to see them bring that over in a G8 version. |
Posted: Fri Oct 23, 2009 7:34 pm Post subject: |
| Dewey316 wrote: | | The only pontiac I want to see is a G8 Bathurst edition. The Vaux VXR8 and Holden version that go the bathurst treatment are truely bad-arse. I would love to see them bring that over in a G8 version. |
I take it you saw that TopGear? That thing so unimaginably awesome. The exhaust note was beautiful! |
Posted: Fri Oct 23, 2009 7:40 pm Post subject: |
| I have seen the TG, i also saw the Aussies do a comparo with all the different Holden versions. |
Posted: Sat Oct 24, 2009 10:25 am Post subject: |
Both of these concepts are ten times sexier than the '10 Camaro, and this is coming from a Camaro owner. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Sat Oct 24, 2009 9:59 pm Post subject: |
The ASC entry is weak IMHO
If anyone can pull it off its Lingenfelter Performance Engineering, they have done some epic work with the T/A in the past. Either way it can only be a good thing  |
