Kage87Z Member
1969 Chevrolet Camaro
Posted: Thu Sep 24, 2009 4:10 pm Post subject: HELP! Loop required for PIR? |
I've been trying to get the 87 ready for several weeks now... and it's close.
BUT, I now understand that a loop is required (and makes good sense) for the front end of the driveshaft.
I don't have a loop. The "universal" ones available here locally don't look like they'll come close to getting the job done.
I'm open to suggestions as to how to get this done, in the best of all worlds, by Saturday afternoon... so I can get this installed and run it before the track closes for the year. _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Thu Sep 24, 2009 4:28 pm Post subject: |
Spohn tranny cross member with loop, or torque arm with loop.
PS: You can run once, and see what it runs. The loop is not required until a certain speed. |
91camaro_rs Member
Posted: Thu Sep 24, 2009 4:34 pm Post subject: |
if you need to make a cheap loop just get some steel pipe, take the drive shaft off on one side and slip it over it and weld it so whatever is there, thats how one of the guys i race with did it _________________
Posted: Thu Sep 24, 2009 5:07 pm Post subject: |
| Dewey316 wrote: | Spohn tranny cross member with loop, or torque arm with loop.
Loop is required with slicks. _________________ A redline a day keeps the carbon away! |
Kage87Z Member
Posted: Thu Sep 24, 2009 5:30 pm Post subject: |
Yeah... I'd heard that slicks=must have loop regardless of speed.
Does anyone have a source for a loop that will work?
I don't have welding skilz or equipment, or maybe I'd take a run at fabricating one.
Any other siggestions or locations where I might be able to get a loop locally? _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Thu Sep 24, 2009 5:37 pm Post subject: |
| Call Paul's shop. |
Posted: Thu Sep 24, 2009 5:38 pm Post subject: |
| Driveshaft safety loop is $40 on Jegs website. |
Posted: Thu Sep 24, 2009 7:21 pm Post subject: |
Are you still running a 700R4 Kelly?
Those cheap jegs ones work, but they really hack up the car.
Best bet is what John said, order up a Spohn Crossmember/Loop. Bolt in. No drilling. Nice stuff. _________________ A redline a day keeps the carbon away! |
Posted: Thu Sep 24, 2009 7:27 pm Post subject: |
I happen to have one. It is red. It is good. It is not used with my TKO.
Posted: Thu Sep 24, 2009 10:08 pm Post subject: |
Not quite. It's not speed that dictates when the loop is required, it's ET. You need a driveshaft loop at 11.49 and quicker, or if you're running non street legal slicks. It also needs to be within 6" of the front U-joint.
Directly out of the NHRA rule book:
2.4 DRIVELINE
On any car in which the driver sits over or in back of the rearend center section, a suitable protective shield of .120-inch (3 mm) minimum thickness steel plate must be installed for those units with universal joints securely mounted to the rearend center section and the bellhousing adapter. Where possible, couplers are recommended in place of U-joints. For straight couplers, the minimum requirement is .063-inch (1.6 mm) aluminum which must contain an inspection cover for removal and inspection of the coupler, securely mounted to the rearend center section and the bellhousing adapter, or as noted in Class Requirements. In place of a crossmember, in the vicinity of the front universal joint, all cars in competition using open driveshafts, must have a retainer loop 360-degrees of enclosure, 1/4-inch (6.35 mm) minimum thickness and 2-inches (5.1 cm) wide, or 7/8-inch (22.2 mm) x .065-inch (1.65 mm) welded steel tubing, securely mounted and located within "6-inches" (15.2 cm) of the front universal joint f or support of the driveshaft in event of U-joint failure. Recommended the loop be round rather than oblong to minimize loading on loop. Open drivelines passing any part of the driver's body must be completely enclosed in 1/8-inch (3.2 mm) minimum thickness steel plate, securely mounted to the frame or frame structure. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Kage87Z Member
Posted: Thu Sep 24, 2009 10:28 pm Post subject: |
| Schultzy89GTA wrote: | Are you still running a 700R4 Kelly?
Yowsa. _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Kage87Z Member
Posted: Thu Sep 24, 2009 10:30 pm Post subject: |
Well, I'd like to take it off your hands... let me know what works for you.... and thanks, S. _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Sat Sep 26, 2009 11:54 am Post subject: |
Thanks Kelly. Good to see you again and good luck at the track tonight.
