fuel pressure ?
PostPosted: Fri Jun 19, 2009 12:23 pm    Post subject: fuel pressure ? Reply with quote
If I had a plugged/partly plugged injector, would my fuel pressure "twitch"?
I know the gauge should casually go up/down depending upon the load/rpm of the motor.
PostPosted: Fri Jun 19, 2009 12:31 pm    Post subject: Reply with quote
Needles aren't always rock steady on an analog gauge.
And no, clogs would actually register a higher pressure I would think.
Define twitch?
PostPosted: Fri Jun 19, 2009 2:10 pm    Post subject: Reply with quote
If your fuel pressure is dipping because of a fuel injector, you would have fuel pump problems. Probably twitching cause of the guage.
PostPosted: Fri Jun 19, 2009 3:29 pm    Post subject: Reply with quote
I havent put the gauge on it yet. Was "thinking" maybe it would help diag the problem.
Twitch=wiggling really fast like a vac leak on a vac gauge.
