Posted: Fri Jun 12, 2009 9:09 am Post subject: Astro Steering Shaft Mod |
Anyone here done the astro van shaft mod? Wanting to do that this weekend as I had to remove my shaft to replace the fuel lines. I am trying to figure out the best way to lengthen it. Any ideas? _________________ 2008 GMC Z71
Posted: Fri Jun 12, 2009 10:45 am Post subject: |
| Explain.... |
Posted: Fri Jun 12, 2009 1:30 pm Post subject: |
| You take an astro van steering shaft, lengthen it to replace the camaro shaft. |
Posted: Fri Jun 12, 2009 1:57 pm Post subject: |
| Why? |
Posted: Fri Jun 12, 2009 3:50 pm Post subject: |
Nope. I used the UE ragjoint eliminator kit.  _________________
Posted: Fri Jun 12, 2009 5:36 pm Post subject: |
I still don't see the desire in putting a solid rag joint in.... _________________ A redline a day keeps the carbon away! |
Posted: Fri Jun 12, 2009 7:33 pm Post subject: |
It gets rid of the rag joint completely. So less steering slop. |
Posted: Fri Jun 12, 2009 7:38 pm Post subject: |
| Twilightoptics wrote: | | I still don't see the desire in putting a solid rag joint in.... |
you don't know what your missing.
(I was one of the beta testers for the UE unit, so I also haven't done the astro van thing...) |
Posted: Fri Jun 12, 2009 9:27 pm Post subject: |
Steering slop is the devil!!  |
Posted: Sat Jun 13, 2009 9:21 am Post subject: |
Guess maybe cause I don't have slop in my rag joint..... Even "warn out" turn the wheel and watch the joint, slop is nihl. _________________ A redline a day keeps the carbon away! |
Posted: Sat Jun 13, 2009 12:32 pm Post subject: |
| I wouldn't really call what I had "slop", persay. More so, the joint "loaded up" and then moved. It wasn't a huge amount but it was worth a shot as getting rid of the last of my steering vagueness. I'll just need to break down and buy/rebuild my box at some point. |
