Hi
Goto page Previous  1, 2, 3, 4  Next
izcain
9sec Club
PostPosted: Wed Dec 10, 2008 9:49 pm    Post subject: Reply with quote
Thezac I think what Schultz is saying is that when you come out with comments about ASE master tech status and knowing it all then in the next post posting odd engine specs it is just kinda sticks out as a little odd. Im not doubting your ASE status im just sayin it came across weird. I know that things can come out wrong no big deal!
As a side note your not the only one with a ASE master cert, Chevrolet factory training, Subaru Factory training, Building race engines for many big names around the peninsula, holding a land speed record with an engine assembled with spare pieces and these guys teach me things all the time! Wink Just saying that this is an awesome group with a lot to offer!
9.17 @ 148
PostPosted: Wed Dec 10, 2008 10:03 pm    Post subject: Reply with quote
This is a pic 2.05/1.60 valves I took a few years ago. I guess in theory they would fit in the 305 bore, but I think you would want to be sure the valve guides were tight. Laughing
Thezach
New Member
PostPosted: Wed Dec 10, 2008 10:26 pm    Post subject: Reply with quote
the erroneous fault i made was stating 1.94 when i meant to state 1.60 and yes, i understand the implications of a simple math problem fitting 1.94+2.02 into 3.76. however that was simply not the case.
And i didn't mean the tech comment as derogatory, merely that i wasn't coming here for a walk through. more of a "to share something different" not ask for help type of deal.
2003 WRX-with VF-39 Turbo, intercooler, and roll cage: my daily Smile
1986 Pontiac TransAM- 305 with custom knife edged crank slightly stroked, H beam rods, 272 edelbrock Cam, 2.02/1.60 heads off of a 1969 camaro, holley fuel pump, corvette ported and polished runners, single serpentine setup
PostPosted: Wed Dec 10, 2008 10:28 pm    Post subject: Reply with quote
No worries man. We are a good group. Things get lost in text on a web page.
Thanks for hanging in there Thumbs up
Thezach
New Member
PostPosted: Wed Dec 10, 2008 10:42 pm    Post subject: Reply with quote
always down for a good argument... especially if big words are used.
PostPosted: Wed Dec 10, 2008 11:09 pm    Post subject: Reply with quote
Eh no argument. We are all pretty interested in your motor, since it is a different combination. So more questions about it, sometimes we just like to discuss technical things too. It may have gotten lost in there, but really it is more of an interest of trying to find out what all your motor has.
--John
Jason_Culbertson
1982 Pontiac Trans Am
PostPosted: Thu Dec 11, 2008 6:56 am    Post subject: Reply with quote
Welcome, im glad to see more Bird's/T/A's. is building a 305 up really worth it? just asking cause i was ether gunna do that or just go out and get a rebuilt 350 for $800.
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Thu Dec 11, 2008 8:02 am    Post subject: Reply with quote
To make the same power with a 305 you'll have to spin it up a little higher than a 350. That's the only difference besides the valves being shrowded by the cylinder walls.
Thezach
New Member
PostPosted: Thu Dec 11, 2008 8:12 am    Post subject: Reply with quote
that valve shrouding deal still has me concerned... by all logic i should have .09 clearance between the cylinder wall and a open valve... but... eh.
and i dont know if its worth it, i need a air intake a radiator fan before i can drive it lol
izcain
9sec Club
PostPosted: Thu Dec 11, 2008 9:04 am    Post subject: Reply with quote
Jason it all depends on what you define as worth it. For me I can remember one instance where I had a run in with a 427 equipped Chevelle against my 305. At the end of it he was just in disbelief and refused to believe that a 305 could have beatin his big bad rat. In all fairness the only reason he did not win is cause he had dinky 235's on the back and I had a set of 295 drag radiels. Simply put I hooked and he burned!
But the look on his face was still priceless to me.
My combo was simple and thought out. Stock crank and rods with arp fasteners, flat tops, world products 305 torquer heads with some mild port work, a street dominator dual plane, comp 270H, roller rockers, hooker shorties and a 750 double pumper. Car ran hard and hooked well. of course 4.10's and a deep 1st gear dig of the 700 let it move away from things quickly. It would take a pretty potent engine to run with the car just cause of the setup. I ran this combo for over 30k daily driven, raced, and cruised on the weekends (come to think of it, in some ways it was funner then the current stroker motor just cause I drove it every day!)
If you put some thought into a combo and spend the money in the right areas it will perform!
9.17 @ 148
Jason_Culbertson
PostPosted: Thu Dec 11, 2008 9:53 am    Post subject: Reply with quote
thanks for the advice, so it will save me money to just keep the 305?
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Thu Dec 11, 2008 10:16 am    Post subject: Reply with quote
Anything you build for the 305 will work for a 350. So you really aren't out anything unless you buy pistons. Rod and crank are the same 305/350 correct? Any heads you buy will swap over.
izcain
9sec Club
PostPosted: Thu Dec 11, 2008 10:52 am    Post subject: Reply with quote
The heads will "fit" although I would not recommend this for reasons stated in this post as well as other. Using 305 specific heads is alright but they weeze out up top in rpms and tend to produce to much compression due to the small combustion chambers.
I would look at it as this....... Use your 305 as a learning engine. Experiment with different parts and such but l8ter I would get yourself a 350 or other and use that as your "real" buildup since you will probably want more power l8ter anyways
9.17 @ 148
PostPosted: Thu Dec 11, 2008 3:57 pm    Post subject: Reply with quote
x2. Don't be rushing to swap in a 350. Work on getting the 305 running right first. As I recall you still have a bad headgasket, and choke. Those two fixes are way easier and cheaper than a 350 swap. Very Happy
PostPosted: Thu Dec 11, 2008 4:23 pm    Post subject: Reply with quote
Nah. If you've got the heads off... 20min more an you have an engine out of the car!
PostPosted: Thu Dec 11, 2008 4:25 pm    Post subject: Reply with quote
Alot of 305 heads actually flow better than 350 heads... when installed with 2.02/1.60 valves. Typcially if you have a 58cc 305 head.. installing the bigger valves will put the chamber size around 64-66 and you'll be good to go on a 350 with flat top, 4 relief pistons! Assuming you're not going forced induction.
izcain
9sec Club
PostPosted: Thu Dec 11, 2008 6:02 pm    Post subject: Reply with quote
Some of the 305 heads have some pretty small runners for serious power. Thats all i was getting at. Any set of heads that are stock are going to take some work to make good power. The price of machine work is something you may want to think about. If your spending X to get the heads done you could spend a little more and have aftermarkets
9.17 @ 148
PostPosted: Thu Dec 11, 2008 6:04 pm    Post subject: Reply with quote
Depends on what you're going for. I made some decent power with my 350 on a set of 416 heads from an '85 TPI car, with 202/160 valves and a Comp XE 262 cam. Ran mid 13's on street tires.
izcain
9sec Club
PostPosted: Thu Dec 11, 2008 6:07 pm    Post subject: Reply with quote
Yea I know what your saying. The 416's were pretty good heads I was just talking stock for stock
How much did you have invested in the 416's?
9.17 @ 148
PostPosted: Thu Dec 11, 2008 7:45 pm    Post subject: Reply with quote
$400 total assembled.
Page 3 of 4
