one car to another
'92 camaro boss
PostPosted: Fri Dec 05, 2008 3:04 pm    Post subject: one car to another Reply with quote
Ok.. so i got my el camino going and all that.. gas is at a decent price..
i was talking with a friend and we decided it'd be cool to put the 400 in the camaro..
what could/couldn't i use with the swap.. obviously i can fit the motor in the camaro without any major issues right?.. along with tranny, and it's an auto.. and i really want a stick, what should i do there?.. and then i got to thinking about the rear ends.. and also i have a '92.. so what effect would that have on my speedo and my tach?...i know you guy's are experienced with this stuff, so what should i do?
PostPosted: Fri Dec 05, 2008 3:10 pm    Post subject: Reply with quote
How would the speedo be affected by an engine swap?
Basically you've got a pretty straightforward V6-to-SBC/EFI-to-carb swap on your hands. There a TON of articles on TGO about both of those swaps.
I'd leave it in the same era of engine/chassis unless you are prepared to go through a learning process.
PostPosted: Fri Dec 05, 2008 3:17 pm    Post subject: Reply with quote
i was thinking bout throwing a 400 in my bird to kinda a throwback to the old formula 400 style i've been tossing that idea around for awile now
PostPosted: Fri Dec 05, 2008 3:35 pm    Post subject: Reply with quote
See now a poncho 400 would be a little bit of work.
PostPosted: Fri Dec 05, 2008 3:48 pm    Post subject: Reply with quote
The 400.. is basically the same as installing a 350. Motor mounts, accessorys, etc.
Use a built 700r4 for the same era as your car.
Why mess with the rear end? Should have 3.23 gears, which is decent for a v8.
'92 camaro boss
PostPosted: Fri Dec 05, 2008 4:29 pm    Post subject: Reply with quote
see i didn't know about the rear end and that was why i was woundering about the speedo, i thought i heard (could be way off) that if you have different rear end's and all that that it will mess with your speedo.. this is just an idea atm.. i am more woundering what a ballpark estimate would be to get it actually going..
PostPosted: Fri Dec 05, 2008 6:30 pm    Post subject: Reply with quote
The speedometer is run off of the output shaft of teh transmission. So the speedometer is calibrated to the rear end gear AND wheel size. Change either of those two and you're speedo will be off.
Chevy High Performance Magazine, Jan 1009, has an article about a 396bbc in a '66 El Camino that had the stock inline 6. Don't know if that helps but it talks a lot and has lots of pictures.
PostPosted: Fri Dec 05, 2008 8:37 pm    Post subject: Reply with quote
yea it would i was thinking just a csb 400 way to much work to do a real pontiac in one of these things i know a guy who was trying lol
PostPosted: Fri Dec 05, 2008 8:38 pm    Post subject: Reply with quote
http://www.thirdgen.org/techboard/engine-swap/229665-v6-v8-swap-read.html
Very useful information there.
As a caveat, your 3.1L Will have the fuel lines on the opposite side as the carburated 400 in the Elky. You'll have to figure out a way to route them to the opposite side.
I don't know if the MPFI V6's pressurize fuel from the tank forward or if it pressurizes at the FPR in the engine bay. Either way, the fuel pressure your V6 runs at will need to be reduced when you put in a Carburated SBC.
PostPosted: Fri Dec 05, 2008 9:03 pm    Post subject: Reply with quote
Stock rear end gear for the 3.1 & T5 is the 3.42.
I believe it's pressurized from the tank. Mine hisses at me every time I crack the gas cap to fill it up.
PostPosted: Sat Dec 06, 2008 9:55 am    Post subject: Reply with quote
Duh I thought you were talking about putting the 400 in the el camino. Sorry man. It won't be that tough to do that swap. Just a couple things you need to figure out.
'92 camaro boss
PostPosted: Sat Dec 06, 2008 1:26 pm    Post subject: Reply with quote
what do i need to figure out?
what kind of $$ would i need to drop.. and the turbo 350 in the el camino, would it fit ok?
PostPosted: Sat Dec 06, 2008 2:21 pm    Post subject: Reply with quote
If the 400 is a SBC then it will bolt up to your tranny and chassis the same as a 350. The stock exhaust may even work. You would have to route the fuel line different, put a non-FI pickup tube in the tank, then wire up the sensors and distributor. Also need to make sure you keep the flexplate with the engine since the old stuff is external balance and the new is internal balance.
Start with the auto. the 700R4 might handle the power but once you get to tuning it and making more power you might start slipping the bands. Once it's running fine though you'll need a T56 to handle the power. Then its the matter of getting the tranny crossmember, torque arm mount, pedal setup, cut a hole in your tranny cover, console shift plate, and convert the T56 to have a mechanical output or convert your dash to electronic speedometer. If your car is a 92 then it probably is an electronic so you would just need a translator box or reprogram your ecm.
Your stock rear end should blow up eventually if you have a 10-bolt. Go on TGO and find the 10-bolt buildup sticky to help it so it won't grenade. If you want to swap it out for something stronger there are other options. I'd swap the rear after you get the motor swapped, just keep an extra 10-bolt around if it does go on you. Is this more helpfull?
I can't really help you with the Elky since I've never had one.
PostPosted: Sat Dec 06, 2008 3:05 pm    Post subject: Reply with quote
On the fueling issue... it's way easier to spend the $70 on a feed/return Fuel Pressure Regulator. It will allow you to run the stock pump, but drops the pressure fed to the carb to the necessary 3-5psi.
The rear end will hold just fine until you put sticky tires on it.
As far as the speedo is concerned... whatever you change, changes the gears to match. (speedo gears in the trans)
