bad tranny?
91camaro_rs
PostPosted: Wed Dec 03, 2008 4:01 pm    Post subject: bad tranny? Reply with quote
so i thinkin my tranny is going bad, when i backing outta the garage and go from reverse to drive or vise versa there is like a 2 second pause before it goes into gear after i move the shifter, and when i get going fast it isnt really wanting to shift, so do you guys think its going bad?
anyone know where to get a cheap tranny?
PostPosted: Wed Dec 03, 2008 4:41 pm    Post subject: Reply with quote
Greetings!
Have you checked your fluid level? If you check the sale section or just wait for a bit you might get some leads on a new transmission.
91camaro_rs
PostPosted: Wed Dec 03, 2008 4:51 pm    Post subject: Reply with quote
yeah i checked it and its fine
izcain
9sec Club
PostPosted: Wed Dec 03, 2008 10:42 pm    Post subject: Reply with quote
You may want to try changing the fluid out with fresh sometimes that will help at least limp it along until you get another trans. You can pick up trans for pretty cheap ( I just gave a 700 away) lol
9.17 @ 148
PostPosted: Thu Dec 04, 2008 12:02 am    Post subject: Reply with quote
Fluid and filter. Check the fluid that comes out. If the fluid is dark, or silvery-metallic, it's time to start saving up for that T-56 swap. Very Happy
PostPosted: Fri Dec 05, 2008 5:42 pm    Post subject: Reply with quote
A T56 behind a 3.1? I don't even think that's worth it! Laughing
91camaro_rs
PostPosted: Fri Dec 05, 2008 11:02 pm    Post subject: Reply with quote
would a 700R4 from a 1985 Z28 w/305 bolt up to my motor? like is the bolt pattern the same?
90droptoproc
PostPosted: Fri Dec 05, 2008 11:09 pm    Post subject: Reply with quote
nope
PostPosted: Sat Dec 06, 2008 12:16 am    Post subject: Reply with quote
I had a working v/6 700r4, but I robbed some of the valve body parts out of it. Would be fairly simple to swap parts from your non working one to make it complete again. The other problem though is I'm as far south as you can go in washington. If you want it and can find transport you can have it. I think all the parts are actually there, but needs a new seperator plate(misdrilled)
