Xmas gift might be AFR heads....
dlp
1990 Chevrolet Camaro IROC-Z
PostPosted: Fri Nov 07, 2008 11:05 pm    Post subject: Xmas gift might be AFR heads.... Reply with quote
I put the engine together for my IROC in the late 1990's. I cheaped out and put Trick flow heads on it, with 1.25 valve springs. The springs are shot due to a bad tranny rebuild that would down shift to far and put the engine at 7,000 RPM.
I should have bought AFR heads but scrimped. I am now in a position to buy a new set of AFR's for Xmas for ride and am wondering if any one has experience with AFR heads. They would be installed on a ZZ4 short block, 1'3/4 headres, T-Ram intake, dual pattern Comp cam - .488 intake, 509 exhaust etc, 114 LSA. Are they worth the dough and how much HP are worth over the old style TF twisted wedge heads? ?
Magman
PostPosted: Sun Nov 09, 2008 1:06 am    Post subject: Reply with quote
I'm running the AFR 190's, L-98 Angle plug milled to 62cc. Late 80's technology. The new heads flow substantially better and I think there's a few ponies to be had if I swapped mine. Just haven't convinced myself that spending another 2K plus is worth it. AFR's are a great set of heads, you can't go wrong, plus you can sell your's to offset the cost.
1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012)
