Posted: Thu Oct 30, 2008 12:07 pm Post subject: Cleaning A Carburator. |
I'm getting ready to dissasemble the Double Pumper I bought not long ago and rebuild it.
Its got some surface rust in some areas, and some serious discoloration inside the carb, probably from years of use.
I'm trying to find a cleaning solution that will take most of the carbonized buildup and discoloration out and not completely ruin the dichromatic finish on it.
If I do have to strip the finish off in order to get all the gunk off, is there a way I can restore it, or basically get it back to looking like it hasn't had years of use?
Any suggestions guys? Will Castrol superclean be too abrasive? _________________
redlava Member
Posted: Thu Oct 30, 2008 12:59 pm Post subject: |
| carb cleaner and a scotch brite |
Posted: Thu Oct 30, 2008 1:47 pm Post subject: |
Your carb has no finish left. It's going to look old. Period.
Soak it in pieces, in gasoline, with a cover (not sealed) for a day or two. Then clean it with brushes, carb cleaner, air. |
Posted: Thu Oct 30, 2008 9:00 pm Post subject: |
got it. Thanks for the input guys. _________________
