Posted: Wed Sep 03, 2008 11:41 am Post subject: First time dyno advice |
Is there anything I SHOULDN'T do? I'm going to dyno the V6 this friday up here in Bellingham. Never done it before and figured I should. Just to see how I did with my engine "build" a few years ago. My torque converter lock up line isn't hooked up so thats good? My tires are getting bald (1/8" left) but 245's, has plenty of traction in the dry. I'm pretty low key anyway i just don't want to do something stupid or falsley assume anything. _________________ E30
Posted: Wed Sep 03, 2008 12:31 pm Post subject: |
just be polite and do what the guy tells you to do. you should be fine
~JAKE |
Posted: Wed Sep 03, 2008 1:37 pm Post subject: |
Add nitrous.  |
mrpopo573 Member
Posted: Wed Sep 03, 2008 4:01 pm Post subject: |
Install a rotating strobe on your roof. Turning this on during dyno runs will increase horsepower.
2000 Maxima SE 5 Speed VQ30
Posted: Wed Sep 03, 2008 7:21 pm Post subject: |
You should be good. Just don't hit the brakes.  _________________
Kage87Z Member
1969 Chevrolet Camaro
Posted: Thu Sep 04, 2008 9:08 am Post subject: |
Have a trailer standing by for when you blow up your transmission. It'll save time. _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Thu Sep 04, 2008 12:15 pm Post subject: |
well if its as light hearted as you guys make it I should be fine.  |
Posted: Thu Sep 04, 2008 12:18 pm Post subject: |
Well, we make OUR dyno get together's light hearted....
Unless there is a tutu bet involved. Tutu bets are SERIOUS business. |
Posted: Thu Sep 04, 2008 12:29 pm Post subject: |
I've seen the pictures I know enough to stay away from that.....
Well then, look for a dyno post of a 3.25 over-cammed custom tuned V6 coming soon! Just going to check the plugs and clean it out before I go tomorrow at 5pm. |
Posted: Thu Sep 04, 2008 2:49 pm Post subject: |
get-r done  _________________ 2008 GMC Z71
Posted: Fri Sep 05, 2008 7:22 am Post subject: |
So wouldn't you know it.....
Last night I decided to clean the plugs and check the cap. Well, I ripped the clip out of the boot of #1 hole. I pulled all of the plugs out and they were all kinda nasty with light brown buildup. Probably due to how rich its been running. Plus I'm never nice to it when I drive it. I have 10k on the motor in the last 2 years. Poor motor. So now I have to leave work early so I can get a new wire and new plugs put in. Then off to the dyno. |
