Posted: Fri Jul 18, 2008 4:59 pm Post subject: Cyl Honing tool |
we had a discussion a few weeks back about a honing tool and you guys were calling it dinglebarry or something.
Do they make a smaller version of that for say brake pistons n such?
Reason I ask is I'm getting a new set of cast TPI runners in and I want to smooth the inside of them out. I cant seem to find a flexable shaft locally for a drill. Then it becomes what tool do I use for the end of it? I am thinking the hole will be to big for my dremel?
Any ideas? _________________ 2008 GMC Z71
Posted: Fri Jul 18, 2008 5:10 pm Post subject: |
| They do make smaller versions. The good thing about them is they dont remove much material, so i'm not sure if thats what you want. For porting work I bought a sears rotozip type tool. You can get it with a flex shaft that will hold dremel type bits. The tool itself will handle 1/4" bits like carbides or 1/8" dremel bits. Plus it does alot of other things. |
Posted: Sat Jul 19, 2008 3:14 am Post subject: |
I already have the flexshaft for the dremel.
So the hone tool likely wouldnt do what I want tell I get the main part down and try to start smoothing it out.
grrr. |
